- 27 Apr 2014
I do not know man, I have like 3 NVME and M.2 SSD in the Tomahawk motherboard. I use a PCI-E Adaptor for extra NVME in case that internet sleuth is watching what I type.
I also tried -15 on all cores except strong cores (0 & 6) which I set -5, LLC on mode 4, +200Mhz offset
This held out in R20, but crashed on the menu in a game.
I would be interested swapping chips with Gerard / anyone who seems to have a 'good one' if only to see if the different motherboard has any affect. Of course, this is not possible (well it is but isnt going to happen)
I dont know how AMD / Intel can get away selling chips that are really good / really crap for the same price. Surely just test each one to make sure it can hit X without failing. Basic quality control
@79c
with a ingame temp of around 50c
i can no longer get my Infinity fabric @1900mhz for some reason with this bios so im going to have to tune a new fabric stable speed + memory damnt there is always something you fix one thing something else breaks...I've seen a lot people not able to get stable with -15 all core or 2 best cores or any cores, and that's including other forums. -5 seems to be the universal given on all cores. As suggested in this thread earlier, I got it stable at -5 best 2 cores, -15 the rest, but that was only after setting PBO scalar to 10x. I also have my DRAM/SOC/IOD/CCD/VDDP voltages manually tuned to support my mem and FCLK overclock. LLC is auto. Cranking out pretty solid numbers
Ryzen DRAM calc FAST preset with Rec voltages etc.
fixed my issue with a bios update lol
1.225v @ 4.575ghz fast enough for me with a 29k multi r23 score@79c
and single core performance all cores reaching @5.05 and lots exceeding 5.1ghz and 5.224ghz![]()
now i have a new issue HAHAHAi can no longer get my Infinity fabric @1900mhz for some reason with this bios so im going to have to tune a new fabric stable speed + memory damnt there is always something you fix one thing something else breaks...
Exactly the same for me. Manual OC locks single core boost to 4.7Ghz if 4700Mhz is setSo is your single core boosting to 5ghz+ automatically when your set at 4.7ghz all core?
Once I change any setting on mine the single core speed gets locked to the all core speed.
I thought that too. AMD presentation was to set a higher negative curve on stronger cores, not weaker. I'm going to try -15 on my 2 strong cores and -5 on the restInteresting. A larger negative offset on the weaker cores seems counter intuitive to what AMD is suggesting in their presentation but it's obviously working for you so I may give it a try to see if the multi-core performance improves.
My memory is next on the list. I have it running at 1900 on an untuned XMP profile, was dithering over whether to tune further incase the next AGESA would better support 2000 FCLK (crashes my machine right now), but might do it anyway.
I guess the devil's advocate / manufacturer's perspective is if it runs to the advertised performance (e.g. 4.8 on a 5900x or 4.9 on a 5950x) you are getting what you paid for and anything else is a bonus. It is still frustrating to hit a brick wall though.
If i bought a shirt that was £50, I would expect the same shirt that someone else bought for £50 to be identical, not have better stitching than mine. CPUs should be no different.
Same goes for other tech, if I bought speakers for £500 i would expect the components to be the same in the same models. Not different speakers but the same model having more capable components that can be driven to produce better quality sound
Thanks. I tried similar with my voltages from DRAM calc. Stable for a CPUZ validation but crashing instantly running R20.
I'm still thinking this is a BIOS thing. PBO limits to motherboard set really high VDDG voltages, a lot more than DRAM calc max.
What motherboard do you have out of interest?
I don't disagree but it does pose some interesting dilemas. Assuming that manufacturers can't completely eradicate variation in the silicon without tanking their yields and their entire business model, I guess is the answer for AMD and Intel to bin for golden samples and price them accordingly? How different fundamentally is to what is currently done with say, 3600 / 3600x / 3600xt? Is there a risk you end up paying the same for an 'average' CPU and a premium for the golden sample?
MSI x570 godlike
Thats why there is spec and there is silicon lottery. This is overclockers, nothing is guaranteed.If i bought a shirt that was £50, I would expect the same shirt that someone else bought for £50 to be identical, not have better stitching than mine. CPUs should be no different
@1.225
with all core temps @73c and single at 46c
cant lock it at 1900 anymore on this bios though lol 30+k on all core r23 Don't want to be the one to burst your bubble. But have you checked your performance matches the apparent clock speeds?i can go as far back as neg 20-30 with 200mhz and motherboard limits enabled and still have no instability.
Whats your SC MC Cinebench scores at those settings?
I suspect you have a case of clock stretching. CPU sees that it is not getting enough volts and drops performance, although clocks seem to be high. It was covered in depth last year with Ryzen 3000 undervolting hype.
though your probably right i might be getting a little clock stretching but im still happy with the results and temps.Think that is stock 5950X performance territory, at 4.3-4.4GHz. So it does look like clock stretching.over 30+k on r23 seems right for 4.650 all core.
But your single core looks better than fine... And that is stable? No random reboots?
i have never heard of this clock stretching stuff lol am i just not supplying enough vcore ?? as i have headroom
Might take a while, but why don't you try testing 1 core at a time if you are struggling to get stability by making mass changes.I tried negative 5 on 6 cores and positive 0 on my two known good cores. Motherboard PBO limits, 200Mhz offset
Everything seemed fine, R23 passed, CPUZ validation, R20 passed, Prime95 max temps 86c after ~15 mins.
5050Mhz boost, 4.7Ghz all core
Seemed great, scores were all about right then failed a third run of R20.
So, not stable and something is crapping it out.
