The L2 cache itself is segmented, and isn't a monolithic slab of SRAM. Each of the eight memory controllers on the GM204 is ideally tied to its segment of the L2 cache. Also tied to these segments are segments of ROPs. With NVIDIA reducing the L2 cache amount by disabling one such segment. Its component memory controller is instead rerouted to the cache segment of a neighbouring memory controller. Access to the crossbar for that memory controller is hence slower. To make sure there are no issues caused to the interleaving of these memory controllers, adding up to the big memory amount figure that the driver can address, NVIDIA partitioned the 4 GB of memory to two segments. The first is 3.5 GB large, and is made up of memory controllers with access to their own segments of the L2; the second segment is 512 MB in size, and is tied to that memory controller which is rerouted.
The way this partitioning works, is that the 3.5 GB partition can't be read while the 512 MB one is being read. Only to an app that's actively using the entire 4 GB of memory, there will be a drop in performance, because the two segments aren't being read at the same time. The GPU is either addressing the 3.5 GB segment, or the 512 MB one. Hence, there's a drop in performance to be expected, again, for apps that use up the entire 4 GB of memory.
