All of you are RTM'ing each other trolling. It's pathetic. If this continues I'll just close the thread and put people on the moderating queue.
You've been told.
I dont know what this means?
Trollers....yes...get rid
What does RTM mean?
You've been told.
Trolling aside. Any chance you are running native 4K Locky ?
What does RTM mean?
Says the guy rocking a 980.
people grassing on each other basically..
What does RTM mean?
To be fair I've blocked quite a few people in this thread as there are the obvious ones that aren't adding anything to the discussion and are clearly just baiting others.
Funnily enough most of them are the ones without a 970.
You must know from using your V1 account.
You wont believe me, but had I had 970 SLI I would still be as I am today
Hi Guys,
I’m Rick, a Product Manager for NVIDIA based here in the UK. Although I read the Overclockers forums a lot and work with the guys here, this is my first post.
If you’ve got any specific questions I’ll do my best to answer them.
Thanks
Rick
Then why post LambChop, you are clearly stating that you could care less about the issues other users are facing and not trying to find a solution. A civilized solution ofcourse that won't hurt OCUK.
Difference between UK vs US law.
Also, Sony did just have to pay out for advertising the Vita as cross play compatible on PS3 when actually that functionality was limited.
Either way it's irrelevant here as consumer law in the UK protects the consumer so we don't need to raise class action lawsuits because our contracts of sale are with the retailer.
It'd then be up to the retailer to get compensation from the manufacturer.
