How about the Infinity cards that you were involved with? Does that fall under OcUK branding?
I can also announce already that anyone with a KFA/Galax card, this also includes the Infinity card can return the card if the customer wishes, because again our customers are kings.
Please bear in mind the following:
• There is no issue with the 970 product, this is by design from NVIDIA in the 970 GPU
• There is approx. £150 delta in the price of the 970 vs. the 980
• There is only a 3% performance delta of the 970 vs. the 980
In short the 970 remains the amazing product it has always being, nothing has changed, stuttering issues are an issue across all GPU's and drivers will of course be released in the future to help remedy such issues across all GPU's.
Some performance stats:
In order to try and assist further we have included some performance data below so that you can see actual testing results between the GTX 970 and the GTX 980.
Shadows of Mordor: GTX 980 GTX970
<3.5GB settings: 2688x1512 Very High 72FPS 60FPS
>3.5GB settings: 3456x1944 Very High 55FPS (24%) 45FPS (-25%)
Relative performance difference: 1%
Battlefield 4:
<3.5GB settings: 3840x2160 2xMSAA 36FS 30FPS
>3.5GB settings: 3840x2160 135% res. 19FPS (-47%) 15FPS (-50%)
Relative performance difference: 3%
Call of Duty: Advanced Warfare:
<3.5GB settings: 3840x2160 FSMAA T2x, SS off 82FPS 71FPS
>3.5GB settings: 3840x2160 FSMAA T2x, SS on 48FPS (-41%) 40FPS (-44%)
As you can see above the relative performance difference varies from 1% in Shadows of Mordor, to 3% in Battlefield 4 or Call of Duty: Advanced Warfare. The performance differences between a 970 and 980 in the above examples remain a constant 15-19%, regardless of memory usage.
I hope that the above information helps clarify the performance from the GTX 970. Please let us know if you do want to continue with a step-up on your product for the higher performing GTX 980 card, and we'll get that option opened up for you.
Still if you wish to return your Galax/KFA2/OcUK 970 you can still do so, please contact our returns for the procedure.
