Aune T1 is fantastic if you manage to get a decent one.
Errr, yeah, been reading around and supposedly it's a 1 in 3 failure rate
![Confused :confused: :confused:](/styles/default/xenforo/vbSmilies/Normal/confused.gif)
Any other options please?
Su
Su
Joined the Group, only Lime left but they are only to replace my ageing Goldrings for general PC use so should be OK![]()
The list becomes VERY long if you're going up to £400 though...
Ffs missed out again .![]()
Has anyone used the HIFIMAN EF-2A? Looks like it might fit the bill![]()
Haha, I've already spent way too much on all this stuff... massively over budget
I'm hoping I won't run into any USB problems - the USB "decrappifier" thing seemed like a bit of a gimmick tbh?
Doesn't the T1 do the job of both the Modi & Vali combined? Is there any benefit of running it through the Vali?
When you stack them, I'd put the Modi on the bottom if I were you, the Vali will get a little toasty with the vents blocked.
