Hmm this is promising news:
OLED monitors are about to get a ‘comprehensive breakthrough’ in image quality
TCL says it has made comprehensive breakthroughs in image quality and lifespan for OLED monitors and laptops with its new tech.www.digitaltrends.com
In other news regarding VRR flicker, playing the new Alan Wake 2 expansion and it's just as dark as Silent Hill 2, but because the frametimes are way smoother, there is very little VRR flicker. So really we should be fighting to get devs to optimise their games more than OLED makers to combat VRR flicker. The game engine method solves both problems.
I guess if you don't have variable frame rates, there is no variable refresh rate, so there is no variable refresh rate flickerframetimes are way smoother, there is very little VRR flicker
VRR still has responsiveness benefits, and there is a difference between bad frametime and good in the way it manifests visual issues like flicker. Disabling VRR is one thing sure, but in doing so for most gamers this then introduces frame motion juddering with Vsync on (and latency), using fast or adaptive sync can result in dropped frames, so frame pacing can be affected, , or motion stuttering with it off depending on the GPU etc, A lot of variables that VRR was designed to remedy.I guess if you don't have variable frame rates, there is no variable refresh rate, so there is no variable refresh rate flicker
although I find the whole matter overblown. Just disable VRR
I disabled G-Sync and just set vertical sync to fast and no more flicker.Noticing VRR flicker in dark scenes whilst playing Silent Hill 2.
FPS fluctuates between 50-100 with 70 being the average. But in door scenes I do sometimes notice the flicker.
I think to compensate I'd have to lower the DLSS quality down to get more consistent frames.
Some argue that you should bit have to do that and therefore they won't do it
I agree though, if on the odd occasion if you notice it and it bothers you just do that. Simples.
I've been running with GSync off globally in NVCPL for a while now, absolutely no loss in motion smoothness at all with a 4090 so there is that benefit I guess thanks to the GPU, and now there no VRR flicker in anything anywhere. Lowering GFX settings or DLSS etc will make no difference as the same shade of grey and dark tones are still there in the game causing VRR flicker as that's one of the main driving factors.
As of of now if you have a capable GPU, then my recommendation based on my extended personal testing is Vsync off globally, Gsync off globally, frame cap ON on a per game basis based on what that game can comfortably run at on average, so if it averages 90fps, then set the framecap for the game in NVApp/CPL to 85fps etc. As a blanket, I run all games now at 100fps or 120fps locked. This means the GPU is only running at around 60% utilisation typically unless it's a path traced game. Means lower temps, lower fan noise, a better overall experience.
You'll have smooth frametimes, smooth motion panning, the lowest input latency.
Chasing high fps numbers in most games especially single player is relatively meaningless once you hit 85fps+ - Personally I am all about efficient/quiet high end gaming where possible.
What if we leave gsync on but cap the FPS?
You will still get vrr flicker as frametimes are never perfect especially in UE5.What if we leave gsync on but cap the FPS?
