Caporegime
- 18 Oct 2002
Furry muff!! I'm at 138 though, helps a tad
The monitor? 240Hz 10-bit as always, this is the first game I have played where VRR flicker is actually very annoying, as said the entire game is dark so you see it every time you walk indoors anywhere in the whole game.What did you set it to?
tried 120Hz VRR, still the same VRR flicker. Ah well, fixed refresh it is.
Furry muff!! I'm at 138 though, helps a tad![]()
The other problem is setting to 120Hz I can 100% see and feel the motion loss vs 240Hz even on desktop just using the mouse cursor or dragging windows around. 120Hz is a literal downgrade by all accounts after being on 240Hz all this time!
Yes but would have to be running the game in exclusive fullscreen mode which has the black screen delay as refresh rates switch over when alt-tabbing and stuff. I paid for all this hardware to be able to minimise a game and browse if needed so i damn well will do that without the black screen delay annoyance!Could you not set it just in the game menu or make a profile in nv app/control panel to have it at 120hz for just that one game?
Have to agree, have tried the AW32 and it's silky at 240! The Asus isn't too bad at 138, can def tell a tad over 120.
Thanks, I'll passSwap plus £1000 coming my way?
Ah shame. Was hoping that would fix the issue tbh!
Here's hoping we get a firmware update that helps like we did with the 34" Alienware.
How long after release of the monitor did they get a patch out to fix the issue in the 34" Alienware?
Everyone is going to have their own preferred settings but I use the 'warm' preset mode as I found that worked best for me.AW2725DF could you recommend me guys some settings for this monitor,pls?
Do I need switch on freesync/gysync in the monitor menu?
Game Enhance mode offEach time when I turn on pc monitor will display frame rate in the top left corner.
How to disable it for good? Game Enhance Mode
thanks
