exhale on the mark and wipe it quickly before it evaporates, don't push too hard, repeat exhale if neededI have some screen cleaner but it really doesn't do a good job and only creates smears of it's own so what do you guys use?
A damp clean microfiber cloth and just wipe in circles. The streaks will fade as they evaporate, or better yet use a dry microfibre to them wipe away the any streaks to a perfect gloss
what game has flicker? I only noticed it on the initial loading of stalker 2 but it stops after a few seconds.
I think I read if your framerates not fairly stable you get flicker.
set monitor technology in nvidia control panel to whatever option isn't g-sync.
then under vsync there should be an option for VRR.
see if that works better
btw isn;t Gsync premium dead now so gsync compatible is all we will get going forward?
Gsync premium (ultimate) was never a label in nvidia control panel, it's always been listed as "gsync compatible " - All Ultimate is was a dedicate dmodule that was better for HDR during its years of release until monitors started to get proper HDR certification. The rest was just a lightly wider lower VRR range and aditional testing by Nvidia to certify etc.btw isn;t Gsync premium dead now so gsync compatible is all we will get going forward?
I've got one, initially bought at launch in Feb but returned that one as the eye strain was ruining me.Anyone running the AW2725DF? Tempted to pick it up on the black friday deal + work discount for ~£550, but also torn on waiting for a 3rd gen WOLED 27", but then you go down the whole DP2.1 rabbit hole...
Wondered how others are getting on? Any issues with eye strain?
My one was delivered this morning. Need to set up and spend some time with it.Anyone running the AW2725DF? Tempted to pick it up on the black friday deal + work discount for ~£550, but also torn on waiting for a 3rd gen WOLED 27", but then you go down the whole DP2.1 rabbit hole...
How did you overcome eye strain . Not sure if I had set up something incorrectly or I need to get used to it but it's bad atm.I've got one, initially bought at launch in Feb but returned that one as the eye strain was ruining me.
Ended up giving it another go in April and ordered again and have been using it every day since April as my main monitor (alongside a 25" 240hz 1080p IPS monitor). No issues with eye strain on this version outside of what I'd experience normally by staring at a spreadsheet for 12 hours straight.
I'm not sure whether it was a firmware update, running it with slightly warmer colours and a lower brightness (warm preset, brightness at 71%, contrast at 79%) or whether it was just a bit of an unlucky panel the first time round but since getting it in April I've used it so much without any of the issues I had initially. I love it, fantastic for the games I play (The Finals, F1 24, OW2, Horizon etc.) and it's been no issue for working with either. The text clarity for me isn't an issue unless I really look for it and it's worlds better than what I had on the 240hz LG OLED. I'm sure the latest 480hz WOLEDs fix that with the updated sub pixel layout but really wasn't good on the 1st gen release.
360hz is great and 1440p is ideal as a resolution for me because I can still drive higher frame rates with my hardware and I'm sort of limited to 27" with my current set up.
My only frustration is the 2 DisplayPort inputs (rather than 2 HDMI) and the gimped HDMI 2.1 that's actually HDMI 2.0. Not a real problem as I run my PS5 at 4k60 (rather than 4k120 because I'm not playing high fps games on console) but a little ****** from Dell to market it as the 2.1 spec, and annoying to have 2 displayport inputs as it means I have to run DP to USB-C for my work laptop.
Pixel cleaning is great too, I honestly never realise it's even occurred as it runs every 4 hours (that the panel is on) and I typically try to take a break from work every 2 hours for 10/15 minutes and it'll have run in that time. The only time I ever see it actually running a pixel clean is when I switch it off at the end of the day.
£550 is a great price, I got mine for £616 (also with a discount + work discount) but I really can't fault it.
I think eye strain is going to be subjective and it's worth trying to see if you're impacted by it - and Dell's service/return policy etc. are all fantastic in the UK. I'd be pretty worried buying an ASUS monitor and having to deal with their customer service whereas with Dell there's a level of confidence in dealing with them.
You'll definitely find that it'll get better after a few days as your eyes get used to it - but also don't be afraid to tweak settings.How did you overcome eye strain . Not sure if I had set up something incorrectly or I need to get used to it but it's bad atm.
Thanks for the comprehensive reply, really useful! Ended up pulling the trigger and ordering last nightI've got one, initially bought at launch in Feb but returned that one as the eye strain was ruining me.
