It honestly ever so slightly puts me off getting another Dell / AW monitor.![]()
I'm watching it.
I'm watching it.
I've managed to go since Feb without it sneaking on. I'm normally good with stuff also, driver updates disable from Windows updates via registry and group policies etc. Never seen on pop up in optional updates. I'm thinking 24h2 had something to do with it. Will check settings when I get home tonightIt honestly ever so slightly puts me off getting another Dell / AW monitor.
You also might not have Freesync/Gsync enabled, then there's no flicker to notice at all!Don't know if its down to my build or the games that i play but I didn't notice any flicker on mine screen.
Just wondering guys have any of you gone back to 27" 1440p from 32" 4K?
Christ, over a metre away?! I sit about 60cm away from my 27" 1440p monitor.27" 1440p is fine as long as you sit back far. Like say 4ft or more.
/Whips out PG42UQ at about 70cm awayChrist, over a metre away?! I sit about 60cm away from my 27" 1440p monitor.
Yeah I like 4k for how great it looks - but I also play a lot of high paced fps games and so I do feel a benefit of playing at 240+fps. Not sure I've got the hardware to be playing games at 4k 240fps though right now. Looking forward to seeing what 27" 4k OLEDs are revealed at CES.Then you would benefit from going 4K sir![]()
Am 70cm away from my 35" 3440 x 1440 UWChrist, over a metre away?! I sit about 60cm away from my 27" 1440p monitor.
you can do this.I'm watching it.
It still tries to install it even if you have just the DisplayPort cable in, have tried this myself before and it still comes back with a vengeance.windows won;t install that crap if you don't use the data cable between the monitor and your pc, but it probably disables anu usb hub the monitor has :/
