So I read the review and everything.. Would you guys recommend this monitor as a TN panel for a person who wants freesync? I just noticed it's in stock here, so I am gonna go and pick it up on Friday.
I mean after the color adjust profiles.
To be honest, you're probably better off waiting to see what comes along. Unless you've got money burning a hole in your wallet or are happy to buy this then upgrade again next year. If you plan to stick with this longer term, you might regret the decision. Plus AOC have one heck of a gaming line-up for next year, or so I hear.
On the other hand, I haven't rushed to pack this away and send it back and am still using it. If that tells you anything.
What if I say that I don't have a monitor and I need to buy one for my R9 390?
Then it would depend on the games you play and how competitively.
ok, got my replacement monitor today, and it would appear to have the new firmware (i.e. overdrive settings aren't greyed out when 144 hz is chosen).
Personally, as stated above, I find this whole overdrive thing a bit of mcguffin (?)but if said info helps anyone here, all to the good.
More to the point I'm beginning to think I must have an unstable gpu as I'm still getting the flickering (much more obvious using 144hz - but think I've seen it at least once with 60 as well).
It's generally not that obvious in game (still talking Morrowind here), but rather when on loading screens (or oddly, when still in game, but having brought option buttons up with the escape key, and clicking on them i.e. 'save' - very obvious when I do that ....)
I did mention the monitor 'reporting' to my OS that refresh rates of 30, 29 and 25 hz interlaced are useable - but with neither monitor has it been possible to successfully apply them (just get the 'wiggling' 'shakey' desktop as mentioned).
Could someone else test this (PCM2?)? and let me know their results?
Might help indicate if it's me or ....
I assume you're using the latest AMD drivers? I believe FreeSync may still have issues with moments in games where the frame rate is capped below the lower refresh rate floor of the monitor, for example 30fps or 25fps as occurs during certain loading screens and other such 'menu' content in games. I saw this on the XL2730Z I tested a little while back in a few games but assumed this was ironed out with newer FreeSync drivers. I didn't specifically observe this behaviour on the G2460PF. I can't do any further testing as it's all packed away ready to be sent back to AOC.
.ok, got my replacement monitor today, and it would appear to have the new firmware (i.e. overdrive settings aren't greyed out when 144 hz is chosen).
what kind of flickering are you talking about here? ive noticed some corner flickering, but it's related to freesync as when you disable it, it stops. sometimes when alt tabbing with freesync enabled, you get a weird resolution distortion/flicker, which is solved by alt tabbing a few times.
i imagine these issues will be resolved in later driver updates from amd as it matures.
i would test it on another machine or gpu as you say, i havnt seen any flicker on the 390 so far apart from the types i have described. - i also limit frames and have not seen any flicker at 144hz with it on.
either way you should be able to tell with another gpu.
edit: which display port cable are you using? the one that came with the monitor i presume?
Hi all
I also have our official driver for you! still unsigned as it is missing the WHQL approbation from Microsoft however exclusively to you...(drum roll!) ... actually don't build it up as I don't imagine I have posted the linked correctly! (fingers crossed)
To install them on Windows 8 or 10 you have to disable driver signature verification.
[URL="http://www.howtogeek.com/167723/how-to-disable-driver-signature-verification-on-64-bit-windows-8.1-so-that-you-can-install-unsigned-drivers/"]
Hope this helps
Hi all
Ok so once again,please accept my apologies for the Freesync issues we had on our launch of G2460PF, FYI "G2770PF" was not affected as we managed to stop delivery into the market.
I have some good news for you
Overclockers stock is shipping today! so will be in stock either later today or tomorrow.
Hope this helps
thank you for the reply, i am still being told by aoc via email that there is no stock and no eta, i havnt contacted ocuk about it, should i go through ocuk instead?
edit: i am afraid that the drivers do not lower the freesync floor for me - or windows 10 isn't applying them correctly. i am using windows 10 64bit pro, firstly i uninstalled all of the older drivers. i then rebooted and rebooted again disabling driver signature verification.
once booted i right clicked the monitor (which showed as pnp monitor(standard)) and selected update driver software..
clicked browse my computer for driver software, followed by let me pick from a list of device drivers on my computer.
next i clicked have disk... and clicked browse and navigated to the g2460pf.inf download from google drive.
clicked open, windows complained that the driver wasn't signed but i selected install anyway. once done rebooted and checked the range and the amd freesync windmill and the floor is still 48hz.
http://www35.zippyshare.com/v/N4Fg514n/file.html
http://www35.zippyshare.com/v/KpaBnydw/file.html
http://www35.zippyshare.com/v/nerDC0wX/file.html
http://www35.zippyshare.com/v/01j99Ixo/file.html
http://www35.zippyshare.com/v/WZmg7rhS/file.html
http://www35.zippyshare.com/v/OxMEPaN0/file.html
hmmm, I'm windows 10 64 ... and I thought it was working.
I haven't looked at the .inf file in Monitor asset manager, although will do, but the Windmill demo let me test it down to 35hz, and seemed to be working as it should be (although more on that anon!).
I will say that it seems to be a bit of a black art to make sure that windows actually applies the driver (I'm never quite sure which options to take - although your description sounds right) as opposed to just telling you that the most up-to-date driver is already installed...
but I take it your monitor asset screenies are definitely taken from the 'new' driver provided today.
