***** AORUS DID NOT INVENT THE GRAPHICS CARD, THEY PERFECTED IT! RTX 2000 SERIES!! *****
In what games(s). Run a benchmark like https://benchmark.unigine.com/heaven at system resolution on max settings but not in fullscreen.
Have GPU-Z and MSI afterburner up on screen and post a screenshot after about 10mins of that running.
Mine has been fine since dropping the power limit to 110. Assuming yours is still stock settings?
Might also be worth taking the OC of you CPU for the time being.
My power limit is a100 it installed like that .
Temp is 83 after 4 hours of doom ran inte cpu diagnostic no cpu errors . Running. Out of ideas .
Ran the heaven benchmark for 20 mins highest temp is 83 all CPU’s are in the 40,s framerate fluctuates.
How annoyed you must be. I have just had a BSoD after about 1hour of Monster Hunter World. I had the OSD on as I know how demanding it is, temp climbed upto 83 before the BSoD hit. This game is crazy demamding fps was high 40s at one point but normally 55-60 maxing GPU, max settings bar AA.
It does seem to be temp related for me, not sure about yours if the FF XV benchmark crashes.
Have you set a custom fan curve to max fans to see if that helps?
I have my fan set manual at 75% and I’m always keeping a eye on the temps to mate so much for the nvidia drivers stopping blue screens lol .
I have had 3 crashes in a row after 10mins of play. First two said something like DXGI error errors on one game then a different error in Tomb Raider - along the lines of your PC cant handle these settings. Even though the GPU is only at about 80percent load to maintain 60fps in most areas.
Im reluctant to send it back as im OCUK would fine no errors the same as scubes. I have removed OC from GPU see if that helps but its not really a solution.
They couldn’t find any faults with mine 5 mins of final fantasy benchmark and black screen did your do this seanyc5. I’m not sending mine back but this has taught me to never buy another card till after all the early silicon is more stable .cant believe these white lights are still on but when she is running it’s great but when the Bsod start it can’t be annoying ..
Let me no how it’s goes seanyc5 with this clocks cos if your is stable so should mine be to hopefully good luck mate.
Yeah stock settings in Afterburner and played for over an hour no crash, temp was about 76-77 and core at 1920ish. Maybe my overclock is just not stable will increase by like +20 from stock see how that goes.
Wot is your power limit at ? Mines is st a 100 this right or wrong .
Its nor right or wrong, 100 is the default. Cards should capable of 122 though as thats what the BIOS allows.
I just tried a different game with stock settings eg. 100 power limit no overclock. BSOD after about 1hour temp was at 80c.
I think I will wait for another driver update or two and then maybe looks at RMA, not to concerned as I have a 4 year warranty. I never used to get any crashes with my 980ti.
If it was at 1920 that's about a 150mhz oc above what it is sold as capable of.
Try underclocking in 12mhz steps with fan as high as you can tolerate see if it gets stable
You can set power limit to whatever you like
I’ve never had this much hassle not gonna bother send mine back cos it will be for nothing maybe look at a new bundle next year .
Yeah that's what they boost to out the box. 1770 they say - to get that I had to apply a -180mhz I think it was.
Anyway I didn't try that I went with -48mhz with 100 power (I know its just to test it but I/we should not have to underclock factory OC cards out the box haha). Darksiders 3 crashed after 40-45mins temp was about 75c fans always on max.
It crashes to 'no signal' on TV, the problem I was having when I first got and the PSU seemed to resolve it.
Im not convinced I needed a new PSU, 650w should be plenty - most off the max draw figures are around 350w. Slowly running out patience now but not sure OCUK would be help as they wasn't for scubes.
