Aorus Master / Extreme (3080+3090) Thread
They say radiator inputs should be higher than the CPU so the air bubbles stay in the radiator rather than in the cpu pump causing increased heat
I'm running Ryzen 9 3900x idle temps 31c and whilst stressing the gpu the cpu is hitting no more than 42c and gpu 54c.
I think the way i've set it up will be ok and even though i have the design for a 360mm rad i only have space for 240mm and as i've chosen a 280mm
i just cant fit it with above with my blu ray drive and 3 x QL120mm exhaust fans on top
Yes it runs perfectly i'm using the setting enthusiast 2 and it cycle between temps and usage, Also have the text set to my lighting effects and from shut down it loads my settings straight away without having to load my os (win10).
God knows why it wont work for me then. Just be a conflict of programs like NZXT CAM or icue or something...
No the radiator needs to higher than the cpu pump but tubes should be down
Otherwise tubes up air bubbles will go back into the pump.
@GIGA-Man Hello, it's near the end of the week and there's no new information on anymore Gigabyte cards coming in. Do you have anything you can share with us please? OCUK's main competitor appears to be getting cards in next week, will OCUK also be getting a delivery? The lack of any solid information is really getting quite frustrating now.
Also if this competitors website is accurate then they have no outstanding pre-orders of the Aorus cards yet are still getting a delivery. Should these cards not be prioritized to companies that do have outstanding pre-orders?
39->31 on the 3090 Xtreme, so don't know if any shipped or if that is cancelations
Pretty sure my AMD 5950X is going to arrive before this even though I was queue 412 for that!
Quite a big jump in the low 3080 Xtreme queue I went from 19 to 7 (originally 27) and it sounds like those were at least to a part actual deliveries since a few guys talked about getting 3080 Xtremes delivered a few days ago.
Mine went from 47 to 34. Getting closer to the front of the queue!
