well good to hear about the e-sata, what htc phone do you have? I have the original desire(not the hd, the one with the slide out keypad or the s).
crezzlin is it just the eyfinity you're have the problem with? does it work ok with xfire on 1 monitor?
hopefully I'll finally get around to swapping out the q6600 etc for the i2500k etc in a couple of weeks.
hi sorry not been on for a bit, was running on a Craig h50 i think a good air cooler would do better. Hows yoursmust be gutted mate, hope they get it sorted soon. you could post on the TT forum and see if you can get an official response or get them to look in to the problem
4.8 sounds greatis that on air?
Was thinking of one of these boards for a new build,but it seems some people are having problems with the bios and other issues.Trouble is I think the actual board itself has a lot of good up to date features, but I don't obviously want to buy an unreliable board so.......
Can anyone re assure me that this board is generally ok and reliable as I am so tempted.
Mark
I use this board no problems what so ever fantastic bit of kitrunning at 4.410 on 1.26v rock steady, all my peripherals, work perfectly.
Could any please tell me what I should install off the CD? So far i've installed the LAN drivers, Audio drivers and RST drivers.
I haven't yet installed INF Driver, Onboard VGA Driver, Marvell SATA3 Driver and ME Driver simply because i dont know what they are/do.
I also haven't installed any of the Utilities for much the same reason.
Thanks
INF is the chipset drivers. Should really be the first thing you install, then Intel Rapid Storage Drivers. Again I'd source everything Intel direct from the Intel website, or at least check the versions against the Asrock website.
Latest are here: http://downloadcenter.intel.com/Det...hipset+Software+Installation+Utility&lang=eng
Hey guys I was about to buy this board untill i read a few posts on this thread
Can anyone confirm that the board is actually running ok with all features working? (with latest bios)
Does anyone have SLI running ok if so how many cards and how many monitors? setup? results etc?
can anyone confirm the warranty that comes with this product? as that is one of the other things off putting to me....is it really only 1 year? compared to most asus/gigabyte/msi boards which have 3 years it seems a little short to me.
Thanks
Phil
Just wanted to tell everyone that Asrock just released another BIOS update ver. 1.30 on their site for the Z68 Extreme 7 Gen3.
The note say:
1. Patch Creative PCI audio card.
2. Patch Logitech MX518.
Congratulations on your first post.
It's only taken nearly four years.
We look forward to hearing from you again in 2015.
