** ATi X1k/HD 3k series overclocking guide - ATi Tray Tools and ATi Tool + FAQ **
after playing about with oblivion I have notice that the clocks were not stable. I think it might have something to do with 6.4 cats im using, im going to uninstall and try 6.3.
If you want a game to test it oblivion is perfect as it pushs the card to its max.
Im gonna have another play tonight.
Cheers
Puck
Anyone else not able to pass 801 mhz on the mem?
Whatever I do I just cannot get past 801mhz, 805/810 etc all checkerboard in the 5th or 6th test of my 20 Loop test of Nature in 2004 with AA and AF enabled @ 1600x1200.
Mem voltage is on both mem + other thing..
625/801 @ 1.400/2.120V = fine
650/801 @ 1.425/2.120V = fine
650/810 @ 1.425/2.120V = 5th test checkerboard
650/810 @ 1.425/2.140V = 6th test checkerboard
625/810 @ 1.425/2.140V = 6th test checkerboard
650/810 @ 1.450/2.140V = 6th test checkerboard
650/810 @ 1.450/2.160V = 6th test checkerboard :mad:
675/801 @ 1.450/2.120V = 20 passes and still going
Temps are under 65C (90% fan @ 65C, 100% at 70C).
I would expect increasing voltage would keep it stable for long enough, but it just doesn't. Increasing the bottom voltage did nothing, well so far :(
Any ideas??
Or I got a **** card? :(
CR.
Right ive been testing and testing, Heres my results
711 core 801 mem 1.440volts on core
Any volts more then the memory corrupts. I think i could get the core running better but at the expense of the memory clock. do you think thats worth ago? or should i stick with better memory? :confused:
I have not tried lowering the mem volts but i might give that ago.
but i think what ive got to is pretty good as ive just hit 12k in 3dmark2005 with a 1.8 opteron running at 2.75gig:)
Cheers
Puck
Argh!!!
MS FS 2004 = works @ 675/801 @ 1.45/2.040/2.040/1.580
EVE Online = works @ 675/801 @ 1.45/2.040/2.040/1.580
BF2 = crashes @ 675/801 @ 1.45/2.040/2.040/1.580
Im getting so ****** off with this card.
Any ideas? :(
Concorde Rules said:
Argh!!!
Any ideas? :(
Lol, tell me all about it :D . Bf2 is fussy :p
I can't wait to switch over to nvidia again, ocing is so much easier(except from voltage control). Still, I did almost pulled 11,3k in 3dmark 05 with my x1800xt :)
So, what's the best oc here yet? No offence, but 675/801 isn't too much of a overclock... We all can't be lucky, eyhh?
Nah, this XT is bog standard/failed/pooey etc.
Next time ill wait ~2 months then buy a XT-X or whatever the top one is...
Clairvoyant said:
hmm
Everytime I try and run ATI Tool I get a blank screen, and have to reboot.
Anyone else had this problem.
ATi Tool.
Using the latest Beta 14?
My screen only goes blank when the clocks are too high for the voltage.
Set 1.4/2.089/2.089/1.500 then set 650/775.
Conc
SpudMaster said:
Im at 750/870, not the highest oc on here but still pretty good i think :)
Damn. Those XTX's really do have sweet memory. I've got 1.1ns stuff on my XT, and the highest I can get is 830.
790/830 is my highest clock, but I use 750/800 for 24/7 use.
Are you WC'ing the memory, out of interest?
