** ATi X1k/HD 3k series overclocking guide - ATi Tray Tools and ATi Tool + FAQ **
Jimbo Mahoney said:
Damn. Those XTX's really do have sweet memory. I've got 1.1ns stuff on my XT, and the highest I can get is 830.
790/830 is my highest clock, but I use 750/800 for 24/7 use.
Are you WC'ing the memory, out of interest?
What score do you get in 05 and 06?
Btw, I'm getting a 7800gtx 512mb today, and I've heard the memory is clocking well :D
Though the cores seem to clock about the same on both the XTs and the XTXs, the memory does certainly seem better on the XTXs. My XTX can get 720/846 on stock volts, and a bump in volts can take the memory to 890mhz for benching with 870mhz for fully stable.
I can get a pass up to nearly 900mhz with my XT, can't do that in games tho, dam ATI stopping XTs clocking :(
On another nite BF2 now runs @ 675/801 when I raised my PCI-E freq to 108 :D :D :D
However that video big is ******* me off clocks go to 400/600 :/
I have tried uping the volt, still blank screen & lockup.
Uninstalled everything drivers, ati tool & ati tray.
Still blank screen and lock ups.
Could it be my power supply is not enought. Enermax Liberty 500W ELT500AWT ATX2.2 Modular SLI Compliant PSU
What else could it be.
:confused:
Are you hitting apply to the voltages???
Tis weird :confused:
Clairvoyant said:
Ok finaly got it to work.
Volts 1.4 / 2.086 / 2.086 / 1.5
Got this then it locked up and crashed
2006-06-06 19:48:26 Clocks set to: 693.00 / 1003.50
DONT USE THE AUTO CLOCKS IT DOES NOT WORK.
Have you actually read my Opening post?
What cooler do you guys advise for these cards, might aswell ask in here as most of you no doubt got one on, either
Zalman VF900-CU Quiet Copper VGA Cooler
Artic Cooling Accelero X2 Cooler
any input will help.
no, just got a dd maze4 gpu block on it and ram sinks, got a 120mm fan under the card blowing air over it too
Clairvoyant said:
Volts 1.425 / 2.089 / 2.089 / 1.5
Core 702 mem 837
Temp 75 c
So is that good for stock Volts.
Beter than mine!!!
I top out at 670/801 at 1.425/2.060/2.060/1.580.
Raise the bottom voltage to 1.580V and try get more mem.
Plus try and keep temps under 70C or it WILL lock.
Conc
Conc - Just read your opening post and a few other threads that you commented it on. Can you help clarify what you meant as i am kinda new to ATI so don't quite understand the concepts.
A guy mentioned he had 9.5K on 3dmark05 but you said that was only 2D mode and should get 11k in 3d mode?. What is the difference?? Do i have to do something to my card profile wise so that it run or enable 3d mode? I kinda briefly grasped this thinking that 3d mode should kick in applications and games when need be or should i require to basically do something software wise before it can run properly??
From reading the opening page what i can tell
"Right, now onto 3D. Create another profile called .3D stock’.
Click settings at the bottom right, from the drop down menu, go to Fan Settings, set this how you want to run 24/7, apply and save to the profile ‘3D stock’. Then go to Voltages and set: 1.4/2.089/2.089/1.487 in that order as you go down the settings. Then apply and save to ‘3D stock’.
Now go back to the clocks page. Set clocks at:
X1900XT: 625/725
X1900XT Crossfire Master Card: 625/725
X1900XTX: 650/775
Apply, then save to the profile ‘3D stock’
That not even into overclocking yet so i can do that without any issues right? I feel i don't need to overclock if i can help it as i think it more than enough to do what i want.
Cheers for any advise/clarification would be appreciated for this ati noob :D.
Kyo
