Jimi said:I gave up trying to get ATITool working, using Rivatuner now and seems to work really well. Managed to get my X1900 clocked at 702 / 801 so far.![]()
But you cant up the voltage on the card using rivatuner... well if you can i cant see it
Concorde Rules said::
Sliders set to perfromace, all AA and AF off? Have you got a 2nd screen you can plug in and watch the clocks on the 2nd screen?
On the ATi Tool not working front, I have no idea mate, I've never seen that before![]()
oweneades said:Hmmm well I am confused. After a lot of tinkering and numerous freezes I seem to have hit a brick wall.
I have got the card to 690/810 and well thats it.
Now here is where I get confused individually I can get the core and the memory up much higher. Yet together I can't. I must be missing something.
What is the VDDCI?! I note in the first page and on other sites it is reccomended to be between 1.55 and 1.58volts?! Surely this is too high as mine is 1.486v at the moment.
This is the main bit that is confusing me. If someone wouldn't mind answering this I would be very gratefull as I would love to be pushing much higher than I am and I know the card can do it.
Concorde Rules said:Well many forums I have seen said it improves mem clocking ability, it certainly did for me adding 30+mhz onto the mem.
Having it at 1.58 is fine according to everythings i've seen.
Keep the temps in check and have 2D/3D profiles and I see now reason why it would break
YOu don't need to shove it up to max now anyway. Just keep raising it until it doesn't do anything more![]()
garethrobinson1 said:Thanks for posting the guide Conc
I've managed to overclock my HIS X1900XT to XTX speeds (650/775) using ATI Tool. I disabled the two services (ATI Poller and ATI Smart as was mentioned in the guide). I ran 3DMark05 and achieved a score of 11,600 using these clocks - I take it this is a decent score for XTX stock clocks (650/775) ?
I also tried overclocking in CCC to see what results I would get using that (disabled ATI Tool too and renabled to two services & rebooted) and got a score of just 10,300 with the clocks set to 650/775 in CCC. Shouldn't I get a similar score to that of when I use ATI Tool (11,600) ?
Thanks for any help in advance![]()
BarryFell said:I'm having trouble with getting ATI Tool to actually do what i'm setting it to do.
I have 3 profiles set up, one for 2D, one at stock 3D and one overclocked 3D. I've set ATI tool up so it should start up on start up of windows and load the 2D profile. I've also set it so it should load the 3D stock profile on detection of a 3D app, which is fine, but my problem is it keeps loading the 3D stock profile from startup. It's like the start up settings just don't work.
Any ideas?
squiffy said:Meh to these useless ATI Tray tools, they don't work, and don't change whenever in 3D mode.
Why can't a overclocking feature be included with the Omega drivers? 2D and for 3D modes? ATI CCC is far better apart from slow down upon boot.
garethrobinson1 said:Cor blimey Conc that was quick
Thanks for the reply mate.
Don't really understand why people use CCC if it loosens memory timingsObviously you would need to raise the clocks significantly higher in CCC to achieve the same performance with lower clocks in ATI Tool.... each to their own I guess
Also, I don't have a dual screen so cannot use another screen to check the 3D Detection has worked and '3D Stock' profile (which is at XTX speeds) has been activated, so instead I use the 'Play Sound' option in 3D Detection - have you used this before? The sound plays when playing BF2, meaning 3D Detection worked, but no sound with Tomb Raider Legend. So i have to force the 3D Stock profile it in that. Bit of a pain in the backside if I have to do that all the time.
garethrobinson1 said:Don't really understand why people use CCC if it loosens memory timingsObviously you would need to raise the clocks significantly higher in CCC to achieve the same performance with lower clocks in ATI Tool.... each to their own I guess
FrankJH said:Crossfire isnt supported in ATI Tool which is why some of us require CCC
