I try to reverse the effects of Darwinism.
And I also do a bit of this too.
I count stuff while people die.
Isn’t that every factory job ever?Are you my boss?
I vaguely try to look busy while doing the bare minimum.
Our workplace made the foolish mistake of setting every single task a fixed time
Used to give a bonus for producing over 100% of your hours in a shift.
This got banned by our regulator.
We now have fixed time jobs with no incentive to do anything more than get the minimum then stop.
It's not uncommon for People to be at 100% about half way through a shift and instead sit there doing whatever.
I rebuilt my throttle bodies![]()
Nor should they. Thank you for keeping thousands in a job to retire poorly developed end user applications though.My job exists because nobody knows how to use MS Access.
