Usually bad pad bedding-in procedure, or regularly holding your foot on the brake after stopping from a high speed.What causes pads to deposit unevenly across the disc?
Just put new rears on the 330ci.
Do you normally get it aligned straight away?
Car seems fine btw.
New rears of what?
Tyres
The only BMW i've spent proper time in is an E87 120d and steering in that was a bit heavy in town but felt spot on :/ Was rather hoping the F31 would feel like that...
Yep, all they've done is repeat what the dealership told me. They've offered me a discount but it's still £1k+ Discs are the one's the came with the car when I got it (from BMW).
F10 530D. iDrive says 60k for both front and rears. I very much doubt they'd last that long but the point is they don't need replacing for wear any time soon.
It's a 13plate but I've had it for about 18 months and done around 15-20k miles in it.How long have you had it and how many miles have you done?
Brilliant thanks.Unless your old tyres worn unevenly, there's no need to get an alignment done if you've just had the tyres changed. Alignment will only need to be done after removing some of the suspension components.
Brilliant thanks.
Last time I checked discs were about £200.00 a pop on ECP without discount code (currently 56% off however), pads 80ish for the pair.Quote from an indy of £554.92 for front dics and pads (F10). Sound reasonable?
This ConnectedDrive business is a bit useless unless you've got an iPhone, isn't it? There's only a few android apps that you can use.
If you don't mind, could you give me a little break down of the various benefits? I gave it no consideration prior to buying the car and have no idea where to start - the only thing I've been trying to do is connect Deezer and I just realised it only works with an iPhone. I've got Connected Services, BMW Online & USB Map Updates free for the next 3 years - is it worth paying a one off fee of £60 for Remote Services?Connected Drive is far more than just phone apps... It's very useful indeed.
seems a bit expensive for a 2.0 tbh!
I'd go for 3.0 as it's a better engine over-all and suits the car much better! afaik it's more reliable too.
http://www.autotrader.co.uk/classified/advert/201703133247690?make=BMW&minimum-badge-engine-size=2.4&radius=1500&model=Z4&year-from=2007&sort=price-asc&advertising-location=at_cars&postcode=ng158hs&year-to=2008&onesearchad=Used&onesearchad=Nearly New&onesearchad=New&page=1
etc
