M135i has much more important factors than a slightly fancier nav thing.![]()
It's not like having the proper system removes those more important factors.
I know this question has been asked a million times, but is professional navigation worth it over business? I've been looking for an M135i for months now and I either find the car which ticks all the boxes but doesn't have pro nav, or the car does have pro nav but isn't estoril blue/black dakota for example. I'm genuinely starting to go insane now.
I don't think it's a budget issue either, as even when I up it from £20k to £22.5k it still appears that this option is rarely ticked. This strikes me as odd considering it's sought after and widely regarded as an essential option (albeit an expensive one). Admittedly I've only ever sat inside a car with pro nav, but in my opinion the larger screen just sits nicely and compliments the interior.
I'm finding pretty much the same thing, have been looking for a 335i in estoril blue but I'm looking for one with xenons, pro nav and wait for it,,,, drum rollllllll,,,,,,,, split folding seats. Found a hybrid 3 which had a load of extras but then found out that the they don't have split folding rear seats due to their design and where the battery is but the newer 330e can have split folding seats. Ho-hum, can't believe that the 3 series doesn't come with folding rear seats as standard.
You could try some cutting compound but it might have damaged the lacquer...
They're not LCI cars, if you can push another couple of £k it will get you into an LCI for the spec you want![]()
That last example is an exceptionally good example and is surely well worth the extra.
This is what I've found with BMW's lately. The older ones seem really poor value alongside the much newer ones. If a 2015 is £22k with hardly any miles you'd expect one with 30-50k more than twice the age to be significantly less but even if you drop down to a 2012 you don't save much money but do quickly find yourself in a world of replacing bits of suspension, bit of wear here, etc etc.
You should be able to get that close to £22k I reckon, it'd be worth pushing your budget to £22k for an LCI car.
That last AUC one is lovely.
In my opinion yes you should but I am biased - I spent 6 months trying to find a nice 2012/13 5 Series and ended up finding them all such poor value that I just got a 2015 instead.
Discounts vary wildly - one particular dealer group won't take a penny off a price others will sometimes slash thousands and thousands to do a deal, but the level of discounts will depend on a number of factors:
a) What the car is
b) How popular that model/options/colour combo is
c) How long they've had it in stock
d) How well priced it is in the first place versus its value
On a keenly priced M135i of which that appears to be one I would not be expecting thousands and thousands off the price but you should be able to get £500ish off at the least.
Most I ever got was £2k - but that was on a 2 year old 335i with wood trim, beige seats and a manual gearbox so I'd imagine they were happy to get rid of it!
Only thing that one is missing is the MPE, but that can be rectified![]()
If you don't mind a higher mileage example I'm considering selling my LCI M135i at some point. It would be within your budget and meets your desired spec.
Admittedly it does seem a bit daft to spend in the region of £20k on a pre-LCI model when £2-3k more gets you inside a very well optioned LCI. Apart from the exterior changes, the LCI comes standard with bluetooth audio streaming, black panel, extended storage, tyre pressure monitoring, business nav, LED headlights and the later steering wheel right? I've also heard it's marginally more powerful.
