https://m.ebay.co.uk/itm/Original-B...899941?hash=item33d4e1cce5:g:AjAAAOSwuLZY376AI can find heated but not auto dimming.
Loads 2nd hand..
No worries!For some reason I was only seeing UK results. Sorted now. Thanks very much![]()
Servicing is condition based, so could be anything from 1-2 years from new, but depends to an extent on how it's driven. My M135i needed its first service at ~23k miles (about 10 months old) and its second at about ~47k miles (just about 21 months old).
Servicing does not have to be done by a main dealer but genuine BMW parts have to be used and the service carried out to BMW's specification for it to be covered within the warranty terms.
Yes, there's still a price hike for the extended BMW onsured warranty over 60k miles.
Yes! Getting really fed up with my Connected Drive and its random dropouts. 2016 640D with an iPhone 6S. Gripes so far:Does anyone have trouble with their ConnectedDrive connectivity? Mine generally works fine (apps, Google, controlling via my phone, etc) however it has twice now completely refused to connect to anything for a period of 4-5 days each time. The car just says 'No Connection' and requests via phone fail, then miraculously a few days later it all comes back online.
Thoughts?
Y
- text messages not showing up on iDrive when received
Yeah you're missing things. Read your manual. It will enlighten you.My main gripe is that there isn't a simple button to change track if you aren't on the multimedia screen, unless I'm missing something? Also there's no pause button, only forward/back and volume down. First world problems I guess
you can scroll track listings using the scroll wheel on the right hand side of the steering wheel, just as you can scroll last dialled numbers if you press the phone button first. The track listings will show up in the centre of the dash display (or in the HUD display if you have HUD).
