Yep.Did the software update fix it?
Just try updating the software yourself. Download from the bmw website then install using a usb
You tend to find the more premium the car the less you get as standard and the more the options cost.Yeah, no electric folding mirrors. No biggies, but I just would have thought that these basic toys would be on as standard on, what is to me, a premium car.
Very much looking forward to getting more miles on it and the roads to dry a bit so I can open her up a bit.
Some niggles though. Auto wipers are crap. They either don't come at all in heavy drizzle, or they come on and stay on permanently even when the rain has completely stopped. Auto light is on and it doesn't seem to matter what I do with the sensitivity rocker switch.
Spotify App integration; might as well not be there. Whether the phone is connected to the car via BT or USB, there is about a 2s lag between any command, and even then it only stays live for about 3 songs before it semi disconnects. I say semi; music is still playing, but the spotify function is no longer available and I cannot skip tracks or manipulate the music in any way. I can skip to BT audio and the music picks up immediately, but BT audio is far more basic. Generally the audio isn't great either. I'd expect at least an EQ; being able to change only bass and treble is quite annoying, especially when my last car at least had a middle option, which is usually what needs adjusting the most. I know the speakers and dimensions are different, but I was actually worried at first that driver door speaker was faulty as it sounds like everything is shifted to the passenger side; I had to adjust the balance/fader quite a bit to make it sounds more centred to me.
I've had a ceramic coating put on my F30 and can't remember the last time I had to use the wipers in the rain, before that leaving the wipers on the lowest sensitivity usually did the job 90% of the time.
I experienced the same issue with a loan 4-series and Spotify, it would work for a while and then simply give up whilst BT audio worked perfectly fine as you say. I gave up after a while thinking it might have just been my phone. You only get an EQ with an upgraded audio system like the HK. Base audio is pants, at best.
Used Spotify every day for the last 18 months in my 330e, no problems and a very handy feature. That's with an iPhone 6+/7+/X.
NVP F11 ownership update... the ****?!
Oil level increase for no reason
That will likely be due to excessive DPF regens, you should get that sorted as it can cause the engine to run on it’s own oil if the level gets too high.
Yeh, a pain though.Sounds like air suspension airbag failure? Quick and easy fix if so.
Yeh, a pain though.
Think it's time to get a warranty to cover all this crap
What's the fix?
I took it to Sytner the day it happened and they drained it and said to book back in for an oil change. Just said "sometimes it happens" and they recommend an oil change when if does.
