- 10 Oct 2006
I've done a few thousand miles in a F31 LCI 335d with adaptive suspension. I think adaptive suspension makes a noticeable difference and is good balance between comfort and handling, the ride is very good in comfort (my wife complains the ride is bad on M Sport suspension cars but no complaints from her, well at least about the ride
) pop it in sport and the ride is then a bit stiffer than M Sport suspension but as Fox says it can't drop the car the 20mm it is sitting higher. Some owners fit ACS lowering springs I personally don't think that is needed I did a road trip with a MK3 RS Focus and E46 M3 it could stay on the bumper of them down twisty roads with out an issue. I've driven M Sport equipped F30s but it was too far apart to do a direct comparison I can't say I noticed much difference in the handling when in sport mode on the adaptive but the improved ride in comfort was noticeable almost immediately.
I think the xDrive system is worth it in the higher power cars as I get annoyed seeing the traction control blinking away as it robs you of power xDrive just grips and goes regardless if its wet or not, if you want to slide the rear around it will do it if you want but takes a lot of silly throttle and steering inputs. I don't think it makes a huge difference on MPG, I averaged 41-43mpg a tank with 50-55mpg on a long run.
LCI does bring LED headlights but they are not as good as the old Xenons, no one then specs the upgrade to adaptive lights and all LED options are in reflector headlights.
iDrive update came a little later so you can have LCI cars with the old system but it is an unusal version that has the new faster hardware with 4G and over the air map updates but the old software interface. You can update the software but I don't think anyone has managed to get everything working yet.
I personally thought it was a great all round car with a good balance between comfort, speed & economy.
![Stick Out Tongue :p :p](/styles/default/xenforo/vbSmilies/Normal/tongue.gif)
