Where I live
Is so far removed from conditions in the UK as to be irrelevant.
Where I live
So you don’t think it’s possible to turn a UK car into a shed in 50k miles? I’d say it definitely is.
Well now you moved the goalposts from 30k to 50k I see your point, but apart from potholes where maybe you could damage hard to see parts, you're not really more likely to damage your car rather than someone who babies it.
But what do I know, I put my brand new bimmer through automatic car washes. Probably a shed now
I’ve seen trucks trashed within weeks of going on the road, burnt out clutches, bodywork damage on practically every panel, suspension damage etc the list is endless and a truck is built - to a degree - to withstand such abuse metered out by supposedly “professional” drivers and are certainly built to take far more punishment than any car.I’ll move the goalposts again actually - thinking about it I reckon a sufficiently poor driver (my grandfather springs to mind) could ruin a car in under 10k. Nothing wrong with automatic car washes - swirls or minor scratches wouldn’t put me off buying a car, but a careless owner definitely would.
You need to start the app and make sure the car is added correctly and 'paired' via the vin. It's not very reliable but does work.
Yeah. All done. I can flash lights, GPS locate, ventilate etc. But not get mileage etc. Says I need to use the connected apps.You need to start the app and make sure the car is added correctly and 'paired' via the vin. It's not very reliable but does work.
Ah OK. Ignore my last reply. Yeah f10.Ah thought it was a g30. I don't know much about sp13 systems and earlier.
It's that bit that doesn't work at all.
trim-wise, from cheapest to most expensive:Folks, I'm completely out of touch with BMW spec and option packs. Can someone explain in layman's terms what the difference is between these below? Ta.
Thanks. Good to know.You have to use a cable connection to update mileage and range.
It's therefore useless. And even with a cable doesn't work most of the time.
I'm thinking run flats on 19" alloys are not the most comfortable of rides possible for an f10.
Turanza er300. 12k on the clock (if not clocked lol) , I think the tread is 7 front and 9 rear.Depends on the tyre. The ride on mine is absolutely fine - I use Goodyear Eagle F1 AS3 RFT.
