looking at a set of winter wheels and tyres for the 5 series. (g31)
I bought a set of 763M copies and tyres recently. My F31 has the diamond cut 5 spokes that are looking past their best. Will run the copies while the OE wheels get refurbed.
Pics requiredI bought a set of 763M copies and tyres recently. My F31 has the diamond cut 5 spokes that are looking past their best. Will run the copies while the OE wheels get refurbed.
Think F30 and G series are incompatible though, probably a smaller market for G series wheelsI bought a set of 763M copies and tyres recently. My F31 has the diamond cut 5 spokes that are looking past their best. Will run the copies while the OE wheels get refurbed.
Pics required
Mine looked like this (went back to 403M in the end though):
I've also bought a 6WB LCD cluster to fit. Going to try fitting and coding myself so hold tight for the "I've broken it!" posts
Are the Icon lights for the F80 that much better than the LED ones? It's one of the few options my car doesn't have.
This is what it has:Do you have the LED lights with the reflector lense? I can't remember if the M3 got the same ones that the rest of the range did. If so, then likely yes. IMO the standard LED lights in the F30 are quite poor, perhaps not even as good as the Xenon ones before them. I am not sure why this is but have always noticed them to be unusual in that they dont have a projector lense. By contrast, the LED lights in the Mini and the 1 Series do have a projector lense and are absolutely excellent..
19" in satin black I think (they were on the car when I bought it) - CM Wheels^^^^^ These are what I have on mine but the laquer has lifted/corroded. Look really bad for a 4 year old car with 45K
Are they 19 or 20? I have bought the 19s in satin gold (it's a dice roll on a black car)
I'll get some pics up once they're on and car is clean. I bought a set of Bilstein B14 dampers with Eibach springs/ARBs too.
I've also bought a 6WB LCD cluster to fit. Going to try fitting and coding myself so hold tight for the "I've broken it!" posts![]()
Hmm I'm not convinced in black, I think would look nice in hyper silver though.
I'm on the fence with them, I have itchy feet to do something to my car but not sure I can be bothered, these are my current rims
Last time I checked (5 years ago!) these were a total pain and virtually impossible unless you bought a new one and at over a grand never made sense for the functionality offered.
Have things changed? I'd be interested in how you get on with this.
Are they the 704M shadow edition wheels? I like them a lot, wouldn't change them if they are in good shape
