Fantastic, that’s good to hear*UPDATE* iOS 16.5 fixed my CarPlay connectivity issues
Absolutely, it was so nice to just sit in it tbh, it had stood up to the years very well, no cracks on the dashboard, as I say, everything still worked, I’m still blown away by how smooth and rattle free the engine was, never mind the fact it started!!That is so cool.
Definitely a re spray we think, there’s considerable “orange peel” so it looks like it’s had paint there - badly - at some point, the rest of it though, especially given it had just a snow foam and rinse off, is remarkable given the layers of crud that it was buried under, ironically, I suspect the very same crud had actually protected the paintwork which has come up far better than you’d expect…
Someone on YouTube would rip your arm off for this - purely for the videosDefinitely a re spray we think, there’s considerable “orange peel” so it looks like it’s had paint there - badly - at some point, the rest of it though, especially given it had just a snow foam and rinse off, is remarkable given the layers of crud that it was buried under, ironically, I suspect the very same crud had actually protected the paintwork which has come up far better than you’d expect…
It turns out the car was parked in said garage fully functional - thankfully with the handbrake off! - with no issues, it was replaced by an e36 and a 4x4 apparently and simply left where it was for nearly two decades.
No mould inside, nothing wet, even after a good jet washing the inside was still dry, quite astonishing tbh!
Yes, I noticed the staining on the bonnet insulation, it's certainly had some coolant issues in the past although as it stood the coolant was at the correct level and a nice deep green colour (assuming it should be green of course!) it was telling us on the dashboard that the coolant was low even though it wasn't, and it didn't overheat once up to temperature...nice - proper car - traditional environmentally friendly paints that last.
had had a clearcoat issue on the bonnet of a similarly aged bmw, at the time, chose a cheaper replacement salvage bonnet rather than a respray,
didn't know whether the head gasket problem & coolant over-pressurization/escape contributed to it;
that has had some coolant projection onto bonnet insulation.
Update on my GPS issue.
Tried to refresh the ATM unit which handles the comms Inc GPS.
Only to find it missing from the car. Dealer took it out to look at it... beaxuse it wasn't working and forgot to put it back.
They're posting it to me next week.
DOH
Makes you wonder. However, I think this was an honest mistake.Who did you buy this thing from?! Bodgit and Scarper?
Just trim the tree back?I've had to order a car cover because the trees are making an absolute mess over my poor m140i! I thought once we get past the pollen stage it would be ok but they're now dropping that sticky crap everywhere! It will be annoying covering and uncovering it all the time but it's probably worth it. Hopefully it will protect from the deadly acorns in autumn that cause little dents everywhere too
Not my treeJust trim the tree back?
Does it over hang your property?Not my tree
It's not my property. I live in a rented flat and the trees are along the road and hanging over half the carpark, unfortunately my allocated space is on the side under the treesDoes it over hang your property?
Oh I see, yea, cover is best bet then.It's not my property. I live in a rented flat and the trees are along the road and hanging over half the carpark, unfortunately my allocated space is on the side under the trees
