Hmm yep we both do but not wanting to totally dismiss as that is a good point, but my brother had the same camera in his 1 series without issue. And i've had the same camera in numerous other cars without issue. However that is not to say it could be interefering in some special way.do you have dashcams installed? lots of reports of dashcams interfering with DAB.
Fix it, keep it.
EDIT: I run front and rear, my bro just runs front cams. So that kind of rules out the rear cam causing interference.
Yep I can try that although the base is magnetic so not sure if that would still cause an issue. Also the rear cam doesn't have any ferrite cores attached to the cable, unlinke the front so I might try some (cheap fix if it works)Surely you can just unplug them and see if the issue goes away?
Front pads are due, non M-Sport brakes on a 330d 2016 Xdrive......roughly how much fitted at main dealer?
Got quoted £260 for pads....seems high for just pads no?
Looking good!A few pictures of my X5 after is was detailed by https://www.downtothedetail.co.uk/. Really pleased with the result and well worth a look for anyone in Surrey. Dravit Grey is a fantastic colour and really pops in the sunlight.
Glad you’re happy with the result Worth giving it a good look over in the dark with your phone torch to make sure they’ve ceramic coated it properly (if they have indeed coated it) - it can be tricky for a mobile detailer to ceramic a car.
It reminds me of champagne quartz, but obviously much less yellowyDravit Grey is one of the best colours out there, looks so unique in the sun.
If it has ID6, you can get it "unlocked" pretty cheap via ebay people or on some forums. Or ask BMW to do it and pay the premium.Picked up a 2019 540 yesterday. It’s a brilliant car that doesn’t half move when it wants to the point where I need to keep a very careful eye on the speedo when overtaking! Got it in blue as I’m not a fan of black or white cars (no offence intended to those with such colours!). I’ve already removed the silver grill and replaced it with a nice gloss black one - astonishing how such a small, cheap change does to the overall look of the car. I’ll take some pics once it’s stops raining here…
I do have a question as I’m banging my head against a brick wall trying to find a solution. I was intending to buy the CarPlay option but it appears that it’s been standard since 2017. However, when I connect my iPhone I only get the option of connecting by Bluetooth. What am I missing as my google-fu has uncovered no help whatsoever
I’m not getting an option to purchase it online. Take it you need to go into a BMW garage?If it has ID6, you can get it "unlocked" pretty cheap via ebay people or on some forums. Or ask BMW to do it and pay the premium.
Call them and ask. Plenty of places online offer it, however you may need to reapply it after BMW service the car because they may update the car which removes it.I’m not getting an option to purchase it online. Take it you need to go into a BMW garage?
Someone in this thread was offered to have it activated for £200. Worth doing it officially if possible.I’m not getting an option to purchase it online. Take it you need to go into a BMW garage?
