Loads of cars have speed limiters already, its just another mode of cruise control that can be turned off anyway
But not before annoying the hell out of you
The speed limiter will send haptic, audio, and visual warnings until you start driving within the speed limits.You can override the system by pressing hard on the accelerator, but the system will reactivate every time the car is started.
To tackle this, manufacturers will have four options to choose from to alert the driver when they’re speeding:
1. The driver’s foot will be gently pushed back
2. The speed control system will automatically reduce the propulsion power, but you can override the system easily by pushing the pedal again
3. The driver will be sent a flashing visual signal to point out you’re speeding. If you continue to drive over the limit, an audio cue will be activated; if you ignore this as well, both visual and audio cues will be used after which both cues will time-out
4. Similar to the third option, the driver will first be sent a visual cue. If you ignore it, the pedal will vibrate. If you keep ignoring the combined signals, they will eventually time out
Given the choice in say 3 years time, I would rather buy the June car without the above than the July/August car personally.
