Getting a lovely rattle from what appears to be the disa valve. Done a bit of light research but nothing major, has anyone had and fixed this issue?
Not having much luck at the moment are you buddy!!
Didn't have any actual problems with my DISA valve but did remove it to check for play. It's incredibly easy to get out..we're talking a couple of Torx screws and an electrical connector.
There are repair kits out there to fix the rattle, but some people recommend replacing the whole unit as in addition to the valve there's also a vacuum-activated diaphragm in there which can perish with age and cause issues.
