BMW and M Power Owners
Yeah they most certainly changed it at some point, not entirely sure why. Thanks for pointing it out, I honestly hadn't noticed that. Probably just going to order all three parts in total and replace the lot, I will only end up doing the top hose at some point I'm sure.
I am jealous of this guys retro petrol pump & signs (and garage) :(
[TW]Fox;25727099 said:
I don't think it's a valid comparison, the auc offering is more comparable to the annual policy as it has a fixed renewal date, the avoidance of which is the main reason you would opt for monthly. The annual full policy is circa 550 quid and it's this figure you should use for comparison in my view.
This highlights a flaw, if you buy an AUC think about whether it will be over 60k miles a year later if you value the warranty as you will be hit with the higher rate if so.
The annual full policy that you get from AUC is equivalent to a 1 off cost of £724.41 or monthly of £66.30 or over 12 months £795.
That black coupe is fricking lovely. IMHO one of the best looking and most well-aged BMWs ever produced. How much was it?
The Z4M coupe I test drove yesterday was good fun, but I guess you wouldn't expect much less. The engine is a peach, but that's a given really. Also the ride wasn't actually as harsh as I was expecting, but then again the roads I was on weren't too bad.
The steering, gearbox and clutch are on the heavy side, but when I first got in I didn't really notice it that much - it definitely wasn't on the forefront of my mind when driving. In fact I noticed it most when I got back in my Focus and everything felt super light.
Can't say I'm not tempted :D
£4k :) 100k miles, HK audio, sat nav, black leather with memory seats. They wear their miles pretty well I think. It drives lovely, just as I remember them. BMW's inline 6's are some of the greatest engines EVER! (imo..)
Need to replace my Lambda sensor as seems to be running rich and using a lot of fuel. Had a garage read the codes and got this:
Fault code: 10010
Lambda Sensor 1 Bank 1 before cat.
Looking here im guessing its number 12.
http://realoem.com/bmw/showparts.do?model=BD92&mospid=47611&btnr=18_0643&hg=18&fg=10
Does this look correct as I dont really wanna blow £100 on the wrong one.
Edit: Looking around seems it maybe number one.
The above looks a good example, advert reads well and I the current owner sounds an enthusiast. Hope it turns out well for you.
You get the 6 speed on facelift coupes but remember that's a 53 plate on whereas the saloon was facelifted earlier. I'm guessing the later saloons have the 6 speed too
Thanks Tesla. I've spoken to the seller and from what I can tell he is a very genuine guy.
However if the car checks out and everything is fine I'd still like to bargain a little. I'm thinking of offering £2,900? He's told me he's already had a few timewasters!
Thanks for the advice rodenal.
