[TW]Fox;22310740 said:CS5 is not available for the rear size on an E39 with 18 inch wheels![]()
I see
. So F1s are, then, I take it - cool. What are you running? F1s or Michelins?[TW]Fox;22310740 said:CS5 is not available for the rear size on an E39 with 18 inch wheels![]()
. So F1s are, then, I take it - cool. What are you running? F1s or Michelins?I see. So F1s are, then, I take it - cool. What are you running? F1s or Michelins?
Wow, it just gets better and better. As I understand it; not only are these tyres non road legal, they are designed to work in wet conditions.
From Dunlops Motorsport site:
"Wet tyres are made in extremely soft,temperature sensitive compounds that generate grip with the road surface despite the cooling effect of the water. Care should be taken not to continue using wet tyres once the track surface dries as overheating and degredation of the rubber compound will quickly follow".
[TW]Fox;22310597 said:What is this guy doing with an M5![]()
Took it for a drive and the front part of the outer arch on the passenger side decided it wanted to be a knife and cut a nice groove into the tyre whenever i accelerated or turned
I have now knocked it in with my trusty hammer.....snip
[TW]Fox;22310747 said:That would be a fairly lame and petty thing to do.
Why do Alpina D3's hold such a high price? Most are poverty spec without Nav etc?
The 135i does look very nice.I'll start: M135i - want![]()
Why is it that when you can afford these cars your priorities change and you have children and silly mortgage costs. I guess in 20+ years when I've gone though this stage I have some spare cash to through at something big and fast![]()
I'm pretty sure my 9 month old son wouldn't appreciate being thrown around in the back. If I can't use the cars potential then it's pointless having it.
