If you have kids and work full time then you'll know free time doesn't happen often. Wouldn't change it for anything though, he's ace !!!You could always take the car out without him in it... crazy thought but I thought i'd just throw it out there![]()
Someone asked for a pic of an actual BMW rather than tyres chat![]()
[TW]Fox;22312099 said:Worst 'I wish I hadnt spent £27k on a 118i with cloth seats only to find the M135i came out with standard leather for only 3k more before mine was even delivered' post ever![]()
[TW]Fox;22311843 said:I can't be bothered with an apples v pears discussion. You can't cite a car with double the mileage as an example of something being 'overpriced'.
I apologise for being lazy...just wonder if you knew the answer.
How much would he cost to finance/buy a new M135i ?
Rough ball park figure would do, monthly repayment, say over 4 years.
[TW]Fox;22312210 said:Well its £30k.
£5k deposit, £25k over 4 years probably about £600 a month on HP.
How did you get that laser to fire from your eyes?
Also I just noticed the barrel lock on the underside of your boot lid...is that a fail safe for if the touchy mechanism fails? I wonder if my car has that.
Please could a good member of this forum post a picture of their BMW, it will numb the pain
I was just getting across that for what the Aplina has to offer you can have for much cheaper in a better spec'd car.
Im trying to get the handbrake cable off the car so I can get the rear trailing arms away from the car and rebush them.Why are you trying to release the handbrake from the car?
When I did my subframe bushes, the easiest way of separating the handbrake from the car was to undo the bolts at the handbrake lever, and then from under the car pull the handbrake lines away from the lever, i.e. towards the back of the car. We has no joy at all separating them from the rear hubs, however they came quite easily away from the car - so we ended up with the subframe off and then a couple of handbrake tails coming from it.
The lower arms are a bit of a sod. Undo the bolt at the top of the arm and loosen it off as much as you can (the bolt should freely move but be blocked by the output flange of the diff). Then, at the rear of the diff, remove the horizontal diff bolt on the side of the arm you want to remove. Get your jack under the diff and lift it up as much as you can without lifting the car off the stands.
With some wiggling, turning, swearing and pulling you will be able to get the bolt out. Watch out for the little metal tab which drops out when you pull the bolt out - this is what the bolt threads into and you need it to put the arm back on.
Either put some legal tyres on it or sell it before you ruin it.![]()
