Wait a minite, I don't hear £2k worth of work here - do you know exactly what you're getting here!? How can they possibly have given you a price when they have no idea what the issue is??
Cam sensors are about £120 and a 5 minute fit. Diagnostics for £60
Coil packs are £40 each or thereabouts. Hours labour for the lot
Plugs are what, £60? Again an hour.
All the likely suspects do not sound anywhere near an £800 bill let alone £2k to me
It depends. Especially if I have two separate issues - e.g. needing a new VANOS unit, as well as sorting out a misfire - injectors are expensive aren't they, and the codes showed misfiring on four cylinders... I suppose the chap was covering his bases when he said "it has the potential to start getting expensive".
£2k wasn't a quote, he put it to me as a worst case estimate.
Assam? Assam is good![]()
Sorry m8, I only specialise in tea. loltim will verify.
timbob, you're in bedford, if you're prepared to come down to Fareham I can certainly recommend my specialist, your quote sounds ratherand :/
335i's been into BMW today to look at idrive advised failed bulb holders in the rear left cluster, despite the lights working just fine.
Whilst it was there I asked them to look at a loud rattle I had mainly on startup and which I thought was the butterfly valve in the exhaust. Long story short, it actually turns out to be wastegates.
She's booked in at the end of the month for a week for them to look at and sort.It's just gone over 60k and Jan 2007 build car.
Should all be sorted through the Mondial warranty according to them! Thank **** for that!! Are they likely to say I may have to pay for investigative works before full diagnosis due to the size of the job?
[TW]Fox;27729459 said:How long is a piece of string? Depends entirely on what's wrong?
i appreciate this question is circumstance/dealer dependent but how long have BMW typically had your cars whilst completing repair works under the mondial warranty scheme?
