I assume they don't make petrol X3's?
If so, I'd consider a petrol alternative marque if your criteria is as you say.
Edit: Dealer won't budge on price - said it had been sitting at the higher price for 3 months but they can't drop it again unless it is unsold for 6 months![]()
Soo, slight problem with my 328i E46.
I left it standing for a couple of weeks and had to jump start it, which I don't think it particularly relevant.
Once started it pretty much immediately stalled itself and then had a really rough idle and after driving a few hundred meters it started to lose power to the point where with my foot flat to the floor in 1st it was topping out at around 15mph, then it started kangerooing and occasionally getting power before dropping again and generally being odd.
It got better for a little bit but started again on the way down a long steep hill, even going down the hill it wouldn't go above 20ish and with the window open there was no engine noise, sounded very much like it was using about 1/2 a cylinder.
Any ideas what it might be? I'm trying to install INPA and if successful will plug in tomorrow as I guess it's probably a sensor? Unless it could be a VANOS issue? Although would that cause such a drop in power?
No they didn't. And alternatives have been suggested. However, an X3 is apparently a must, despite its lack of suitability.
Basically she wants a Chelsea tractor
But a phoney one.
Nope, unlikely to.
I would do the following:
- Take it to another garage to get them to check the wheel balance again.
- Are your wheels OEM or aftermarket? Regardless, get them to check if they are bent.
- Get them to check your propshaft guibo
- Get them to check your rear subframe bushes.
- Get them to check your rear trailing arm bushes and ball joints
Having a little bit of a vibration issue on my 330ci.
It seems to vibrate gently from about 45mph upwards. It can be felt through the whole car and the steering wheel. Its not too bad and a fairly gentle wobble type vibration but its enough to get irritating quickly! I can feel it through the accelerator as well so your leg feels a bit numb after a whileThe vibration remains when the car is put in neutral at speed.
Any ideas? I have had all four wheels balanced but this doesn't seem to have helped much. I've also checked the brakes after driving and none of them seem to be heating up too much so I've ruled out a sticking caliper. I've also changed the following in the past week or so
Control arms and bushes
Drop Links
Inner & Outer Tie Rods
Front ARB Bushes
Any ideas?
