Scania, did you check the rubber intake boot for tares when the MAF was replaced?
Was a genuine MAF used?
Yeah that is an OEM part so that shouldn't be an issue.
AFAIK those codes are usually from unmetered air getting in or a vacuum leak.
Has the CCV valve and pipes been replaced at all?
The ccv hasn't been touched, no, not felt the need as of yet, it idles perfectly, used to stall a lot but the new cam position sensor cured that outright, it's not stalled or shown a sign of since.
I'm going to pull it all apart later (the engines hot at the mo) and have another close look at the pipe you referred to earlier.
Thanks for the input mate.
Some better pictures of my m135i taken earlier today. Treated it to some iron x, clay bar and a good waxing.
How do you get/keep the shine off the steering wheel?
I've tried Dr Leather cleaner but it doesn't really do much on the wheel
I use a magic eraser sponge carefully then condition/feed the leather after.
Some people would not recommend this but if you are carful it should be fine.
Unless I'm being a berk!... It's a bit rough round the edges
