Seem to have a knock on my e46 when turning left/right and braking (only at a stop). Seems to be more apparent on the front near side wheel but I can't see anything out of place. Also when lifting off the brake in neutral there is a small knock sound coming from the gearbox which can be felt on the gearstick as well. Car is an auto.
Well I did some more investigating. Seems like the knock is coming only when releasing the brake and not when turning. Definitely seems like it's coming from the left front - and only occurs at slow speed (1mph). It will also knock if I reverse or move forward again at slow speed and only when I release the brake pedal.
I'm thinking sticky caliper. May change my pads to see if it's not the pad itself. Any ideas?
I've got a F80 M3 on order...
Should be here on 1st Sept!
It is probably that the pad is slightly smaller than an OEM pad and it shifts in caliper creating a knock or clunk sound. It happens in my e39, especially if you go from forward to reverse or vice versa.
Probably early signs of the droplink.
Hate you! But big kudos for not choosing the odd looking M4.
What colour did you go for? Yas Marina gives me a semi.
Thanks, I prefer the M3 and I need 4 doors.
Yes I've gone for Yas Marina Blue
It never did it before you see. So I'm unsure whether it is actually the pad.
Maybe - it didn't do it yesterday mind you. If it does worsen I'll get it checked out. That also reminds me I think my exhaust is blowing lol.
Intermittent noises like that usually to point towards suspension as it's relates to the weather.
You can't check it out though, needs blindly replacing. It's more likely the drop link than a pad knocking.
