BMW and M Power Owners
[TW]Fox;22760644 said:
70 euros per hour but its capped at 3 hours, so if you pay for 3 hours you can have all day.
Wow!! That's a brilliant deal! You'd be mad not to do that with a car like that!
What's the company? Just in case I ever decide to do anything like that
Mine didn't use an ounce, had 60k on it.
Hmm, interesting. Since I have had my E91 from mid April, I have had the +1L warning light come up once and thus I added said oil, and yesterday, it has come up again. Since ownership, I have put about 6~7K on the clock.
Might be time to have a word with the dealer and get it resolved under the AUC Warranty.
Is the 2.0 a definite no-no then?
I guarantee the performance of the 3.0 will not be utilised at all.
What I mean is, are you saying to get a 3.0 because a nice car should have a 6 cylinder engine or because the other engines are ****?
Thanks for the advice.
Any clarification on this please?
Hopefully going to look at a few on the weekend.
[TW]Fox;22761246 said:
Lol, they won't even want to know about a car that uses 1 litre every 3-4k miles!
It needs to be under 600 miles a litre to get looked at.
ok, so it isn't an issue then? The only reason I asked is because the car is consuming more oil than I am used to with the other motor, but if it is normal then smashing :)
Can't comment on the petrol engines, but my dads E60 530d drank oil as well. Not quite as much as 1L every 3–4k but noticeably more than I was used to with other vehicles.
[TW]Fox;22752873 said:
Pro Nav is the absolutely essential one. Everything else you need is standard so just pick the options you fancy. And make sure it's not a 520.
I disagree.
Adaprive Drive makes a world of difference, especially if you're on RFTs.
Along with Pro Nav, I'd want the comms pack and heated seats and full leather.
If you can find a car with this stuff fitted, comfort seats and the HUD are great featured, although the latter doesn't work with polarized sun glasses :(
I think that Active Cruise would be a great function too.
But unless you're ticking the options list yourself, you'd probably struggle to find a truly fully-loaded car.
There is no coms pack, and leather and heated seats are standard fit. Like I said, everything you need bar Nav is standard, so options are just stuff you fancy.
Dynamic Drive isn't standard. Makes a world of difference.
It's not available on the M Sport.
It's nice to have on an SE but not essential, therefore I stand by my opinion that excluding Nav all the essentials are standard fit leaving just things nice to have on the options list.
Of course. No frills motor with a set of ITBs on one side and nice tubular headers on the other. No rats nest of hoses. I don't need to post pics, do I?
