I've seen inside multiple petrol engines ran on both cheap fuel and V Power and the difference was quite substantial in terms of carbon build up on valve faces and piston crowns.
I've also had the injectors from these engines ultrasonically cleaned and flow tested and the results, again, were noticeable. Injectors ran on V Power had only a slight increase after cleaning (2-3cc/min) where the other injectors were 10-15 times worse.
Proof, in my eyes, that there are detergents in these fuels that are worth the additional cost.
Mine always has premium diesel definitely regens less
Easy on mine, when idling the consumption doubles, from 0.1gph to 0.2.Don't think I've ever noticed mine regenerate. Asda fuel must be miracle fuel![]()
Were the engines run in the same manner? I mean the difference between one that’s been mainly used for town driving compared to one that’s been on the motorway? Or one that’s been driven hard to something that’s been driven fairly moderate? Just curious that’s all.
Premium diesel is cheaper than standard supermarket stuff.
When you drive off without paying?Um. Where?![]()
Um. Where?![]()
Indeed one of the best perks. Always at least 1p less than the Asda next door.Costco
