- 4 Aug 2007
- Wilds of suffolk
The only time I speed is by accident, i.e. if the limit is unclear.
I did a speed awareness course 6 years ago* and found it very useful and quite amusing as the pair doing it had it off to "T". Online is cheaper for them (though I note they haven't reduced the price....) and more convenient for the person taking the course, but in some ways in person would be better if their goal really is reduced speeding.
* Interesting story behind that one. I had Ford Focus at the time which has a stock fault of dry joints on the instrument panel PCB causing spurious electronic issues. I stripped it all down resoldered the joints and solved the problem. But in order to do the job the needle had to be removed from the speedo and I thought I'd get the speedo spot on for accuracy on when I rebuilt it. Big mistake...... Normally speedos are 5 to 10% fast but I had forgotten mine was now spot on when I was driving at an indicated 35 past a speed camera. I was actually doing 35 and got done. I discovered that in Lincolnshire (where it happened) if I'd been going 1mph slower I would not have got a ticket ! Had the speedo been say 7% fast my indicated 35 would have been an actual 33mph, and no speeding ticket.....
Hell of an assumption that normally speedos are 5-10% "fast" and to drive to that.
The law allows a speedo to overread the speed by upto 10% but never to under read.
As such every manufacturer will err on the said of caution, but I cannot think of a car I have driven in the last 30 years thats been that far out.
Typically being 1-2mph out at 70 in my experience.
Mine now is I think 0.5mph out at 30mph, where when I slow to exactly 30 indicated for a camera they will tend to flicker between 29 and 30.
When an external source is used for speed, waze, external satnav etc I tend to get them reading 70 when my speedo declares 72.
My personal approach in unfamiliar areas is to err on the side of caution. So if unsure then 30.
Unless clearly everyone else is going faster, then just match their speed.
If its busy you have a benchmark from others and if its quiet then 30s fine.
Speed cameras should only ever catch non locals most of the time. Locals unless they are either 1) dumb as a sack of rocks and hence get them off the roads asap, or 2) distracted by something else like thinking about their work who get caught should probably not be driving anyway if getting caught by speed cameras.
I remember the speed cameras on the Haughley bends on the A14, where I drove them enough I could lift off sail through at speed limit and then mash the accelerator like every other "local"
Occasionally you would see someone sail through and get flashed who was either clearly unfamiliar and ignoring the limits, or a local who was massively distracted.
Both deserve a ticket anyway.
