has anyone experimented yet with fans in push/pull?
i know gaiden is using apaches @ 1300rpm and some others are using simular but was wondering if higher rpm fans would be better like 1900 or 2000rpm?
apparently the default corsair is being reported as not very good even tho its 1700rpm so wont be using that
i have spare fans lying around from previous builds...
2x 120mm xigmatek 1600rpm
2x 140mm 1200rpm with 120 convertors
a few(6) 120mm Nanoxia FX12 2000rpm fans all these are silent to me so which would be best? or is there another fan thats the king of the hill on air flow with rads?
in case you ask why i havent tried myself
mines in the post still
regards
HRhino"
