Corsair H50 Water Cooling Kit
Didn't Custom PC magazine give this thing a really poor rating for AMD processors??
I haven't managed to pickup this months copy yet, but I am sure someone posted saying that on this thread?
Is it normal to have some rad fns bent a tad? 99% of the fins are perfect but the occasional one seems a bit off, or twisted.
And where in a rad does the water pass through, i was warned that putting a screw in too tight can puncture it, but all i see behind the screw holes is fins, not a water holding tube or anything.
Well I've finally fitted mine but not all the way as I am waiting on the CPU to arrive tomorrow. I have made a couple of short videos which I hope to upload tomorrow once I have it up and running. But all looking good so far. :D
the custom pc review for the amd used a different case to the intel one, iirc it had really chitty airflow which seemed to be the problem. They still gave it a poor rating though, sent my estimation of their objectivity right down.
I got mine yesterday, very impressed with its ability.
Have it in a push-pull config, which is now using dual Enermax UCCL 120mm. Works a charm.
3.2 OC and max temp I have had is 60 degrees with the fans turned practically off!
Sorry about the rubbish state of my case, check back tomorrow for better pictures ;)
Has anyone set one of these up in a Coolermaster Elite 335 Case?
Mobo is a Asus P5Q Pro Turbo with a Core 2 Duo E8400 CPU.
If anyone has can you advise on what fan congiurations you tried and settled on?
Regards,
Simpic
I would be happy if i could see any pictures :p
hi gaiden and bulldog ...
could i ask what thermal compound you using? mx-2 .. mx-3..artic silver?
and what method you used for application? ..such as pea ...line...spread methods? cheers...
now i got the H5O and when my fans arrive im going to try some Tim consultants 0098 grease which is supposed to be very good stuff..
regards
HRhino"
P.S ...i have been tomany hardware store/outlets looking for 4 more of these bolt/screws that come with the H5O but can get any even tho i was informed it was m3 size i couldnt find any exactly same with thread matching..all i found was slightly thinner and thread was more dense...:S are these custom ones??
regards
HRhino"
Here is my thermal paste here (mx-2): http://www.postimage.org/image.php?v=Pq1SiYqi
well looks like my weekend of playing around with the cooler will have to wait as I still have not received my CPU. It was purchased from MM. I have been in contact with the seller twice now and have not heard anything back. Well here is hoping I do get it next week. :D
Well it dos'nt state what case/case cooling he has, or what fans he is using, that temp would'nt be to hard to get if he was using 1 or 2 delta's lol.
Get in touch with the mod of that forum if you don't here anything, just to be safe that is.
Nothing against the guy you got it off(or will).
