** CORSAIR LIQUID COOLING SOLUTIONS - CRAZIEST DEAL OF 2013 **
Well my H100 turned up and its great keeping my system nice and cool at between 29-31
on idle and whilst playing BF3 on Ultra my temps never went above 47 which is great.
Gets a bit noisy though when in game and thats on the balanced profile as well.
Got back to Germany today to do a leak test and so far so good. Very quiet and really cant see any difference between the 3 modes. Think I will use my fan controller anyway.
Gutted just received my H100 and it has no liquid in it, it's all soaked into the box and packaging :(
Good job it took a leak before it went inside your PC.
I still wouldn't feel comfortable with one of these coolers attached to my CPU. The reward is nowhere near good enough for the risk.
Picked my H80 up from clockers this morning and bought one for a mate, mine was pre-ordered £36, his cost £40 :P no signs of leakage on opening the box on either, but there was no 1 year warranty sticker tho :( I think they may have wisened up to it on this new batch unfortunately. Gonna have a play tonight on my standby pc, just incase.....
Well few results:
2500K @ 4.5Ghz 1.41v
H100 Pump on lowest setting with 2x SP120 PWM Low Noise High Pressure Fans at max 1400rpm. Connected to a Bitfenix Recon.
Prime running Large FFT's only ran for 30 mins as know rig is stable but max temps got to 69c.
H80 just arrived, sry if its been asked but has there been a 1150 haswell bracket been released to use these pumps on those cpu's ?
EDIT: ive just read the 1150 and 1155 bracket are identical so shouldnt really need another bracket :)
Just got my H80 today and if i did not know any better i would say it was brand new, the box looks new and all paperwork and packaging look new. Also it has printed on the box ( corsair guarantee 5 years ). And this thing is so well packaged i think all the leakers happened when they were put in the box at corsair, i reckon you could drop the box and not break it. Fitting time next week..
Did anyone else go through topcashback to try and get these a little bit cheaper. I bought the H100 on the pre-order for £39.95 but I have been declined £1.26, by OcUK, in cashback. Is cashback not claimable on pre-orders?
