We have never had any issue with leaks reported. This is a sealed unit
I cant say as I have heard of Corsair sealed watercooling units leaking either. CoolIT's on the other hand, well that's a whole other story![]()
Old Corsair coolers (Round shape pump & block) = Asetek
New Corsair collers (Square shape pump & block) = CoolIT
These ones are made by CoolIT afaik.
Can anyone put my mind at ease as to the leaking?
Return rates for the H100 at Overclockers UK were excellent. 2900+ sold and less than 5% return rate for actual faulty items.
there are no leak problems with the H100
Where would one fit the H100 in a Cooler Master CM-690 II?
top or bottom
http://www.coolermaster.co.uk/product.php?product_id=6644Accommodates 120 x 240 mm radiator inside the top and bottom
http://www.corsair.com/hydro-series-h100-extreme-performance-liquid-cpu-cooler.htmlThe Hydro Series H100: ... Featuring a full 240mm radiator and two 120mm fans.
Radiation Dimensions: 122mm x 275mm x 27mm
http://www.guru3d.com/articles_pages/corsair_h100_review,2.htmlThe H100 can only be installed in cases with fittings for a standard 240mm radiator
+1
These are perfectly fine.
As much as people distrust LCLC solutions they are actually very decent![]()
My guess is 90 days with ocuk like there b-grade and the rest with the manufacturer ( corsair ) + we get free shipping with ocuk.
People who are posting about examples of faulty corsair h100s and using it to as reason to not buy one, of course there will be faulty ones but it is only the faulty ones you hear about. The majority of people's h100s work fine but you don't hear about them as they work fine! If you bought a piece of hardware that was working without problems you probably wouldn't go and write an article about it, but if it was faulty you would tell people and ask for advice. The return rates tell it all.
