Is that beacause your TV doesn't have HDMI?
I'm sure you must know someone nearby who has a TV with HDMI. You could ask nicely and take your PC to try on their TV.
This would rule out any problem with the monitor cable, the monitor and the adapter.
Also, before you do that, try using the other DVI output on the graphics card.
Hmmm actually no its not installed.
When I download the ZIP theres 3 files in there, no install though. what to do ?
Is one of them a .inf file? You'd go to your monitor in device manager and choose update drivers, then browse my computer for drivers, then point to the .inf file. At least that's what you used to do. To be honest I dont think it'll help you. A monitor driver is literally just a list of what modes it can support and not much else. Cant see it having any effect.
