No.
ABS cylinders are available in 5mm increments per side from 30 to 60mm.
http://www.abloyshop.co.uk/abs-cylinder-measuring-guide-15-c.asp
Just had a look on that site and it states that the 30mm lock does not comply to BS-TS007:2012 3 star certification due to only having 6 pins instead of 8.
So not sure if I should keep the 70mm one or send back and get 60mm.
I didn't know you could position the thumb turn to make it inaccessible from outside with key though.
