Here is a question for everyone. Look at the following pair of RCA interconnects.
Providing the rest of your system is resolving, do you think there is any change in sound regardless of what following cable pair is used?
Just by looking? No.
While the cheaper looking cable would have course ask you to question it's design construction, I bet in any normal setting it would be indistinguishable as well..
I'd only buy higher quality constructed interconnects just for the decrease in likelyhood of oxidisation of the connector and also I'm OK with having slightly more robust screening etc...
I'm fine to have my mind changed, either by double blind testing with my own ears, or through the use of demonstrating the difference using measurement techniques that can be correlated to audible frequencies at levels that are indisputably distinguishable
Actually one aspect I have with my scepticism is that if I was sneaky, I'd deliberately construct the cable to have an appreciable affect on the cable, a tiny notch filter to give a V shaped colouration and people would hear the difference and swear it was amazing..
Reading the soundsguys above I did laugh when they said one of the previous tests had the coat hanger being by far the most preferred over a high end cable..
I appreciate good audio gear, but I've yet to come across any differences yielded through speaker cables/interconnects because I do try to get good VFM but well constructed items, the absolutely largest and indisputable improvements have come from improved DAC/AMPs and Speakers themselves, as well as speaker placement and acoustic handling of the environment.
