Easyrider's Playon HD mini review thread.
Can anyone help me.
I have mine with a wireless dongle (realtek chipset no AC Ryans)
I managed to get it to see my Win7 folders I share.
But anything I add new to the drivers shared folder it does not find. But if I delete something that was allready in the folder they are gone on the Playon.
Anyone got any clues.
Yep updated mine last night...couldnt see anything of major difference really.
Still waiting on this new GUI, hoping they release it soon:).
Same here - been using it for a while but doesn't seemed to have changed anything!
The pessimist in me is expecting an announcement from them stating that they can't get GUI 2.0 working correctly on the older devices so we're stuck :p
Model: AC Ryan ACR-PV73100 Playon!HD
Version: v7.3.3 r4824 (Asian) / v7.3.4 r4824 (European)
Release: 2010-12-02
Firmware History
New Features / Improvements / Bug Fixes
Version v7.3.x r4824
what’s new in this release
1. Improved SAMBA compatibility with Windows 7
2. Improved BTPD downloading stability
3. Improved Web Management default page when Login Control is off
4. Improved Web Management compatibility with Safari and Opera browser
5. Improved compatibility with MKV compressed headers
6. Improved Hebrew subtitles display
7. Improved weather channel description
8. Improved HDMI compatibility
9. Improved REPEAT modes images
10. Improved Player Web Management to display correct remote control image
11. Improved auto scaling of video resolution to user defined screen size resolution
12. Add Change system font option in Setup – System menu
• Place your preferred .TTF font in “Resource” folder for selection
13. Add Edit Protection option in Setup – Misc menu
• Protects the Copy menu with a password when option is turned on
• Default password is “0000”
14. Add Browser Mode option in Setup – Misc menu
• Displays your files in Preview Off/Preview/List layout
15. Add new menu language for Asian version
• Arabic
• Indonesia
16. Add new menu language for European version
• Norwegian
• Danish
• Swedish
• Finnish
17. Add Stretch to Zoom In selection
18. [available in previous SDK platform]
Add frames seek function during video playback (video dependent)
• Press left or right button during video playback to jump to frames backward or forward.
19. [available in previous SDK platform]
Add new options in Setup/Video menu
• Plasma mode (Dark/Dim/Light)
• Screen size resolution
20. [available in previous SDK platform]
Add menu for selecting Audio/Subtitle/Title/Chapter/DVD Menu
• Press MENU button during video playback to display navigation menu
21. [available in previous SDK platform]
Improved skipping of music tracks by pressing the Previous or Next button
• During music playing, pressing Next button will play the next track or Previous button to play previous
track
22. Fix flickering of info message during music playback when title is too long
23. Fix unable to resume playback when display is switched to 24p mode
24. Fix loading of Jukebox from network location
25. Fix wrong indication of Audio and Video description in INFO display
26. Fix prompting of password during files deletion in BROWSER even when folder protection is off 27. Fix overlapping of DNS entry portion when setting a fixed IP address for wireless connection
28. Fix unable to eject USB optical drive after being mounted by system
29. Fix displaying of parameters present in certain subtitle format
30. Remove TIME settings (not applicable to model)
31. Rename Folder Password Protection to Folder Access Protection
Wireless and HD network streaming don't mix.
Hardwired is the way to go or stutter free flawless playback and searching and seeking
I absolutely believe this to be true but I've just setup a 5ghz dual band wireless network in my house and I'm dying to see if it works ;)
Anybody know if any dual band 5ghz dongles work with the AC Ryan Mini.
Can anyone help me.
Anyone got any clues on this.
Any ideas here?
Trying to get the Movie Jukebox to work with YAMJ. I have ran EMM, I run YAMJ on the PC and aim it at the internal HDD of the Playon. Generates an index file within the folder of where my movies are stored on the Playon.
Go to the Playon, run jukebox, tell it to look on the internal HDD - states 'No HTML index file' ?? But it is clearly there.
What am I doing wrong people?
Ok so here is another one :D
How do you get the Blu-Ray rips to have a blu-ray cover in YAMJ without having to actually select one for each file?
Running EMM & YAMJ automatically, is there a setting or code or something?
This may or may not help you out, I had a couple of rips that yamj could not find covers for, so what I did was renamed one of my folder.jpgs to the name of the movie and now yamj shows that. Now this is the part that may help you, I also have a HTPC using Mediabrowser as well as playon's in the bedroom and dining room and for all my bluray rips I use a program called stark covers to skin over the standard folder pics to a 3D bluray cover which looks better in Media Browser and this is the image I renamed to the name of the movies that where missing, so now they appear skinned as blurays. There are lots of options and skins with the program.
http://www.hack7mc.com/2009/06/jazz-up-your-cover-images-with-starkcovers.html
Thanks for that Holwill, I'll take a look and see what I can do.
So what kind of transfer rates do people get? I seem to be doing something wrong, as when I transfer a file from my PC to the Playon I get about 4.32mb/s which is useless. If I transfer something between my laptop and PC I get about 7.00mb/s so I know it is not the network.
Any ideas?
How can i record freeview with such an item is it possible with the Playon ?
For example can i plug freeview decoder into the box in anyway.
Thanks jay.
Edit: Sorry for being lazy just wondered if anyone has a work around before i google.
