Some quick thoughts, locked at 60FPS and for some reason although I'm on keyboard and mouse with no controller plugged in it's prompting me for controller inputs, thought it might be a bug with Razer but others seem to be affected. Looks like Q maps to back and E is OK/Select. Also mouse look feels like it's accelerated, or at very least a very high sensitivity, either way doesn't feel right so I'll probably need to adjust settings. Didn't really intend to play tonight, so will wait until tomorrow when I get back from work.
You can change the prompts in the menu settings so that it prompts you with mouse and keyboard prompts instead of controller prompts
I think this is placebo. I already had the shader cache on unlimited.Possible fix for PC frame rate, that according to others seems to work well: https://www.reddit.com/r/Eldenring/comments/t0q22j/possible_fix_for_pc_frame_rate/
Any chance this could get you flagged and banned due to easy anti cheat?Flawless widescreen got a fix up thats working and a few things will follow. Now i can start playing the game![]()
niceee, stupid messages getting appraised
Yeah, what is that about? Never played a DS game before so looking forward to giving this a proper go tonight but suspect a lot of things will go straight over my head, at least initially.
Oh, and I expect to die a lot.
Just played for 3 hours. 4k/Max settings on a 3080 couldn't hold 60fps, drops to 50s in some parts so I changed to 1440p. I tried tweaking the obvious settings like shadows but they look terrible below the maximum setting, some weird flickering. No stutters here.
Apart from opening a chest and getting teleporting across the map to some Bloodborne looking swamp which took me a good hour to get back to the starting area since I didn't have the horse its been good. So I wouldn't advise exploring straight out of the gate, go get the horse!
edit: ok I take back what I said about no stutters, just got to stormgate and the microstutter is pretty bad. will have to fiddle with some stuff, saw somewhere that turning off hardware accelerated gpu scheduling will fix it but I doubt it. Might just pick it up for PS5.
edit2: couldnt fix the stutter, just ordered the PS5. 45-60fps with motion blur on PS5 but thats better then stuttering all over the place.
