Loads of cars require more than £80 worth of fuel, what a bizarre cut off limit (although depressingly i suspect historic not imagining that >£80 will become a normal fill)![]()
Asda and Tesco here both have £99 as the limit for the self serve
Filled the tank from near empty on Sunday, came to about £17...very small tank.![]()
Grrrrr.![]()
Seems to be £99 on most pumps ive used, PITA in certain vans even then!
In a moment of darwin-esque thought, I decided to put Tesco Momentum into my Jeep Cherokee. Think I put 60L in and it was over £80 odd.
I wanted to see if the Jeep would feel different for having slightly more pep in the fuel and if it made any difference to MPG. I also thought well, if it doesn't make any difference at last the next time I fill up it will be cheaper![]()
