keeping my fingers crossed for you![]()
thanks apprecited , as well as the feedback from all users here ... look forward to updating thread tomorrow with results
Well I'm returning my X34 after having it a little over a year - bought it in Feb 2016. It's now showing a vertical purple line on the left side of the panel - not happy for a monitor that cost the best part of a grand.
I agree that in the past I've used Iiyama - back in the days of CRT monitors, wouldn't buy anything else. Hoping that Acer sort it out for me.
If it's within warranty, they should. My x34 is being picked up from DPD within the hour. Fingers crossed the replacement is blb free.
How did you get Acer to pick it up via DPD? Did they arrange that or did you and did it cost you anything?
Thanks![]()
 I should have put a line break between the two statements as they weren't directly relate.  well received my cf791 today
Snip
In all serious though, how is the QC so bad among numerous manufacturers, some of whom have been making displays longer than I have been alive? If you are gonna ask for a grand, you could at least turn the thing on and check it isn't garbage. I genuinely feel bad for the people dealing with this crap for weeks even months on end.
I generally agree but there are so few products out there, at least in the category that I'm after (1440p, 144 Hz, FreeSync), that there aren't really any viable alternatives. If my old VA monitor (which had no BLB whatsoever) hadn't died I wouldn't have invested in an upgrade, but now I can't really go back to 1080p 60 Hz or anything. The plus side is that I don't play games in the dark - if I did there's no way I could put up with the BLB. In a brightened room I can't tell the difference between a bit of BLB and a bit of reflection from the light source anyway so it's not a huge deal.Because not enough people send back crap products :/
There's unfortunately a world full of folks who put up with bad quality items or accept statements like "BLB is a natural part of IPS technology" or "we don't consider less than 18 dead pixels to be a fault". If the e-store listing doesn't say "may suffer BLB" then it's not acceptable to tell me after purchase. Everyone needs to send back everything that doesn't meet reasonable quality standards and insist that they do better. It's the only way to end the race to the bottom.
hell, AMD could actually include "no BLB" in their spec if they really wanted to improve monitor quality.
This!!!!!Because not enough people send back crap products :/
Sorry I didn't see the ambiguity when I posted that, but I see it nowI should have put a line break between the two statements as they weren't directly relate.
Mine wasn't through Acer; it's getting RMA'd via OCUK.
Not sure how effective that would be. 3 out of the 4 members of staff I spoke to said that this was a good IPS panel with no more than perfectly normal glow or blb:Let putting it out there.
I wouldn't mind OcUK charging a bit more if they can guarantee panel quality.
I don't even mind if they pre-screen all the monitors prior to shipping against a standard protocol. E.g. No dead/stuck pixels &a acceptable IPS glow level etc.
snip
