*** Grand Theft Auto IV - MODS & TWEAKS ***
OK so I have uploaded it now, the only thing I would say is to be wary that the contrast may be off (maybe due to my crazy monitor settings), I put the config straight onto my housemate's copy and dark was quite a bit too dark. Probably best changing this in the enbconfig.txt file and if you think night/day are too bright/dark you can tweak them with the adaptation settings in the enbseries.ini
I can only confirm it works with EFLC, the main reason I haven't been using another config is because most of the good ones did not seem to work correctly with it. Use the files supplied in the original ENB from your version and then copy the files in the /skyfall custom/ folder. Be aware that the red sky bug is still present.
I have also enabled the dof effect for when definition is switched off, you can switch off the dof in the enbconfig.txt, sharpening is also enabled and can be configured in the effect.txt. I would suggest though if you're not going to use it to switch it off either way as it adds a bit off blurring if definition is on. Finally you can enable AA in enbseries.ini.
This is what it's currently looking like:
No DOF:
DOF (may be a bit strong for some but can be tweaked in enbconfig.txt):
http://url.csignal.org/66972/
Edit: updated link to latest version.
If you like it, please pop up some screenshots :)
Sky are you using any kind of car pack or are you just installing yours manually
Word of warning, using car packs can cause serious issues, I've tried several, and there is this thing GTA IV does where if you do not have the RAM to load all the custom cars at once (i.e: all regular GTA cars being replaced) you'll be swarmed with Taxi's EVERYWHERE. There is a script to get around this, but that makes the general textures go nuts, extreme amounts of glitches (at least for me).
I have 8GB ram, so if your using 16GB you might be okay for one, but GTA IV is a dodgey one and might still hit you with the taxi setting, and I think my textures went insane after the no-taxi script because I'm on 1.0.7.0. If your on 1.0.4.0 then go for it, but I strongly advise against any content mods in 1.0.7.0 unless you do them individually (avoid packs).
If you get a pack to work on 1.0.7.0, let me know! :)
yeah yeah ive just got the taxi bug :(:(
Best thing you can do is verify caché on Steam to get your original vehicle.img back, and just mod cars in one by one and try not to replace any of the existing cars. You could try the taxi fix script, but if your on 1.0.7.0. with Ultimate Textures, you might get some severe issues, like buildings not loading, road textures rising 3 or 4 feet upwards, cars splitting in two etc. etc.
^ i already have all .img files backed up separately and the whole game backed up just in case ^^
Smart thinking! I've already wasted god knows how many GB of bandwith reverifying, maybe I should backup the big files onto my external HDD now I've wiped all pirated games off it (I'm going clean ;)).
In all seriousness though, I really hope GTA V isn't like Vice City, San Andreas and IV, where they make the game less and less and less mod-friendly with each patch. :(
lol funny thing is..i don't even like GTA4 i just wanted to mess around with it
Vice City is my fav GTA game
I prefer Vice City too, just because of the memories, was obsessed with 80's music when I was a kid so only natural I played it the most. :p
Playing it now though, I'm stuck on the Avery mission where you have to fly the bombs into the construction site, the helicopter controls are so bad on PC, either that or I'm getting to old for gaming :D because I either run out of time or get blown up. =/
I just do them manually, as above the last time I used a car pack I got all taxis =/
From what I've heard they are weird... I use xbox controller, honestly even driving a car feels really weird with mouse and kb.
They had seriously better not only sort out 5 as a port, but they better make it more mod friendly on the PC, most of IV's sales must have came from ICEnhancer and various car mods. Why take a dump on the biggest audience for your game by killing modability with each patch etc?
After Max Payne though, its looking good. Rockstar are great, I remember running GTA 3 on a really old PC I usually DOS gamed on (some pirate game comes to mind, might track it down :D) and it ran perfectly, now IV comes along and demands way higher specs than it deserves and has all these issues. As many work arounds as there are, it just doesn't seem right. Such a fantastic game at core though.
Think I found a nice sweet spot with the DOF between 0.5 & 1.0, got it at 0.75 atm and it just adds a cinematic feel to it.
Edit: Just been making a few screenshots... Definitely liking the DOF:
Similar shot to earlier:
And is it just me, or does this look like a photo:
Also wondering whether I'm going crazy but I enabled Ambient Occlusion and it seems to have increased performance.
Edit 2: (someone else make a post jeez :P) Updated the zip file with more info and default DOF to 0.75.
No DOF:
http://chaoticsignal.com/uploads/Skyfall ENB.zip
Got your config up and running however, my game looks like this and its daylight
Does it look the same as yours if not, what setting shall I tweak to make day look more like day?
I think it looks similar in the shadow but that's probably my monitor...
You can change the min / max adaptation settings.
